interior headliner lights don't switch off automatically
Just wondering if anyone else has experienced this problem and if it is the R11 relay that needs replacing. thanks in advance - Glenn
Yes, I do have them toggled in the right position. They are in the centre position. They lights stay on all the time if they are in the centre or the forward position.
The lights are delay triggered by the little switches in the door jam. Have you tried pressing in BOTH switches (one at a time, and holding for a while) to see if one needs an adjustment?
<edit>: on further review, a maladjusted or broken switch would also raise havoc if your lights were on and the engine was off (I think). As if you opened the door. Oh never mind.
The rubber boot on my passanger door's switch was slightly torn. And this is the side of the car that gets hot from the oil lines running there. That switch stop working recently (would not activate the dome light on, opposite of your problem, Berg). I bought some electric contact cleaner from Radio Shack, and sprayed inside the switch. It started working again, and all was good. I bought a new rubber boot from Sunset for about $3. Looks good as new.
This was actually the first time I've ever "fixed" anything on my car. I was pretty proud of myself. And now I finally get to share my story. Am I ready to handle a top-end rebuild?
No HTwo O ...... Congrats on your repair. I will certainly keep that in mind and have another look. My problem is a little different as I mentioned because my lights do come on and the rocker switches in the headliner appear to be working perfectly - it is just the automatic timer/delay that has stopped functioning. Are you ready to perform a top-end rebuild? - lets just say that I hope you don't require one anytime soon. Best Regards, Glenn
Glenn, I am rock solid at +53,000 miles. No top-end required at this time. My PPI numbers were excellent 2 years ago, and my UOA's suggest my engine is still breaking-in. Maybe someday. But I expect to get another 30-50,000 miles on the Turbo before that's necessary.
I wondered about that right away. It certainly didn't appear so and the engine compartment was closed properly but I will check for a faulty switch.
Maybe the wire on the back of one of the door switches has come off. It's a simple spring switch that grounds the wire when the plunger spings out as the door is opened. I found one of mine off when hunting for a random alarm sounding problem. The wire was loose, dangling down in door pillar and every now and again would touch the bodywork, hence grounding and making the alarm think that the doors were open. I presume that would also put the interior lights on. It's simple to remove a switch - pull off the rubber cover and you'll see a nut to undo around the switch.
