Help suspension 993 turbo
I have 993 turbo wpozzz99zws370443
I wont change suspension and make order springs and shocks
front
993 343 041 37
993 343 042 37
springs
964 343 531 80 504
rear
993 333 051 34
993 333 052 34
springs
993 333 531 16 504
.....and i can not use parts because spring is short or rod in shock is long
I think what i get springs from re-grading.
may be anybody can see how long must bee spings 964 343 531 80 504 and
993 333 531 16 504?My have front 26.8cm(10.5 inch) and rear 29.3cm(11.5inch)
or how long rod(stock) in shocks?my front is 21cm(8.25 inch) and rear 25.2 cm (9.85 inch)
front
993 343 041 37
993 343 042 37
springs
964 343 531 80 504
rear
993 333 051 34
993 333 052 34
springs
993 333 531 16 504
Serg,
I wish I knew enough to answer your questions. Perhaps contacting Gert at Carnewal, or Steve Weiner may be able to figure out how to help you. They are sponsors of ths site, and you should be able to find their contact information. Good luck.
The front springs you list are from a RS, the struts are standard Monroe. The RS would have its own RS only Bilsteins (RS sits 40mm lower than standard so these 2 parts are probably not compatible)
The rear springs are for a turbo but the shocks are again standard Monroe not for a turbo but I would think these would work together
i sent parts back and order again -for my turbo must be original parts
front
993 343 041 35
993 343 042 35
springs
965 343 531 01 504
rear
993 333 051 35
993 333 052 35
springs
993 333 531 16 504
may be this info need anyboby
front
993 343 041 35
993 343 042 35
springs
965 343 531 01 504
rear
993 333 051 35
993 333 052 35
springs
993 333 531 16 504
