Smoke from exhausts on start up
Have noticed a little smoke on start up, but when I drive off its ok.
It only happens after I leave the car for a week or two
Any suggestions?
35k mile 993 Turbo
Any suggestions?
35k mile 993 Turbo
I installed the check valves from Kevin (along with new turbos) and it solved the same issue as you're experiencing. Haven't had one problem in 8 months. You'll need to make sure you have the proper filter as well if you haven't already done so. Anyhow, I can attest they do as advertised.
98C4S, did you read this old post:
https://rennlist.com/forums/993-turb...l-leakers.html
This will help you understand the 996TT oil check valves better.
