Dipstick/gauge readings
If the oil is at the correct level, about 1/3 on the dipstick, the gauge usually reads in the red. Sometimes after an extended run it will read a bit higher. Anyone else experience this? Wondering if I should have the gauge looked at next time the car's in to improve gauge reliability.
Same here... exactly the same. My 911SC has always been that way as well. I've read a few threads about pulling the sender in the tank and bending it a little to get the float to register what the dipstick indicates. I don't think the problem is with the gauge. I always trust the dipstick and have decided to ignore the gauge.
My gauge and dip stick read the same. But, damn, the dip stick is very hard to read. Let alone pull out past the black intercooler gasket, and still obtain / preserve an accurate reading. The oil is very hot, the stick is very hot, and the oil for the most part is clean and not too colorful (dark) to even see on the stick.
Not to get too far off topic, why do some guys run the oil levels on the "low" side?
I don't know. That's the question. Why select "low" or "full"? Why is one choice better (or worse) than the other?
I can see why low would be bad. By running low, you could run the risk of running below low, due to normal oil consumption. But why is full also bad. Full to me does not impy overfilled. It's not like our cars generate more oil and could cause a full car to become overfilled. Overfilled is overfilled (bad).
Properly filled fluids to me seems the right choice. The key being properly done at the right level.
Full, means the oil is hot-hot, car on level ground with engine running.
With 11+ quarts in the system, I'd say that even if its a quart low, its better than being over full
Well, I like my stuff full. My beer mug full. My coffee cup full. My gas tank full, and my oil capacity full.
I don't spill any coffee or beer. I don't get gas running out of the filler nozzle onto the paint. And my car does not leak or smoke or use oil between changes (5,000 miles).
The oil is the life-blood in our cars. I'd like the most that can properly fit. It's easy enough to do. Why not do it.
Again, full is full. Overfilled is overfilled. How is full equal to being overfilled?
Ronnie, I pulled my IC last night to do some work and noticed that the IC hoses were damp, but only where they are on the outside of the IC inlet tubes under the Breeze clamps.
The rest of the hoses and the IC itself were dry as a bone.
The Guap' does not smoke either.
[QUOTE=ScottMellor;7755273]Ronnie, I pulled my IC last night to do some work and noticed that the IC hoses were damp, but only where they are on the outside of the IC inlet tubes under the Breeze clamps.
The Guap' does not smoke either.[/QUOTE
Very interesting. I'll check mine inside. Since no smoke, I'm assuming similar limited oiling...
