993 Turbo Forum 1995-1998
RS sway bar settings
Old 07-15-2010, 03:03 PM
dbf73
Boost Junkie
dbf73's Avatar
Default RS sway bar settings
those of you with RS bars (and ideally PSS9/10's), how do you have the bars adjusted?
Old 07-17-2010, 06:27 PM
ScottMellor
ScottMellor's Avatar
PSS9s
Rear full stiff
Front in the middle
Old 07-19-2010, 11:49 AM
Spartan
Spartan's Avatar
Rear in the middle for me
Old 07-19-2010, 12:19 PM
DM993tt
DM993tt's Avatar
PSS(9)'s all full stiff. Re-valved to 650lbs front, 1000lb rear. F sway bar at middle, rear full stiff.
Old 07-19-2010, 05:48 PM
ScottMellor
See it kinda depends on your setup and purpose.......
Old 07-19-2010, 09:38 PM
DRPM
DRPM's Avatar
Scott & Dave
Are you using the RS drop links with your rear RS sway bars at full stiff?
Would like to see a picture of that set up with wheels on the ground if possible.
thanks
Derek
Old 07-20-2010, 09:23 AM
dbf73
Boost Junkie
dbf73's Avatar
Scott - I understand. just looking for a starting point - after that, I'll exercise my god-given right to adjust myself out of competitiveness
Old 07-20-2010, 11:31 AM
ScottMellor
Hah! How funny and true.
When I first got Frank, he was set up for more understeer. As I did more DE's and became more comfortable, we set him up to try and eliminate as much push as possible.
El Guapo is set up the same way as Frank was at the end. I believe the droplinks I use are RS.
Do you mean that you want to see a picture of the swaybar/droplinks with the car on the ground?
I might could take a pic of the back, but not the front, unless I put the camera on a timer and tossed it under the front end!
Old 07-20-2010, 01:05 PM
cgfen
cgfen's Avatar
bingo!
now let's start a discussion regarding;
what you do to increase understeer assuming bars are set at middle / middle
and
what you do to increase oversteer assuming bars are set at middle / middle
let's use DE / TT type events as a starting point, not AX with it's more dynamic transients.
Please discuss, always willing to learn from others experience.
thanks
Craig
Old 07-20-2010, 01:13 PM
cgfen
cgfen's Avatar
Originally Posted by DRPM
Scott & Dave
i'd like to see it too, there seems to be some variability between cars for toelink / droplink / ARB fitment.
Yes, I'd like to know before i purchase a set of RS ARBs.
thanks
Craig
Old 07-20-2010, 09:06 PM
DRPM
DRPM's Avatar
Scott,
Pictures of the set up with the PSS9 - RS rear sway bars - drop links, please.
Derek
Old 07-21-2010, 09:46 AM
dbf73
Boost Junkie
dbf73's Avatar
stiffen the front bar (move links away from the ends) and/or soften the rear bar (move links towards the ends)
soften the front and/or stiffen the rear
Old 07-21-2010, 03:50 PM
cgfen
cgfen's Avatar
Agreed, that is the conventional wisdom.
I'm trying to discover a bit more technical info regarding why these changes affect grip.
Craig
Old 07-21-2010, 05:59 PM
ScottMellor
OK the simple version:
If the anti roll bar is set soft or even disconnected, that end of the car will roll more to the outside of a corner. This transfers more weight to that outside tire, which in turn increases the grip to that contact patch.
Old 07-21-2010, 07:23 PM
wagongotya
wagongotya's Avatar
have my rear bar set to medium with 800/1000 springs. i've got a set of rear rs drop links just lying around if you want them doug
Quick Reply: RS sway bar settings
