leakdown test results
just had a leakdown test down. car has 46k. midwest eurosport in bensenville (chicago) did the test. as always any thoughts would be appreciated.
cylinder 1: 5%
cylinder 2: 3%
cylinder 3: 4%
cylinder 4: 3%
cylinder 5: 2%
cylinder 6: 3%
cylinder 1: 5%
cylinder 2: 3%
cylinder 3: 4%
cylinder 4: 3%
cylinder 5: 2%
cylinder 6: 3%
i just had a leakdown on a 993 turbo..it was done cold instead of hot which apparently skews the results, car has 28k miles. Results were 16%, 16%,17%,16%,16%,17%....i asked a porsche specialist and they said not to be concerned with the outright numbers given it was a cold leakdown but instead to focus on the % differences and 1% diff was very good. Any thgts on that view given the individual cylinders read so high or is that what you'd expect from cold vs hot leakdown?
Drivelikeyoustoleit> you have some good leakdown numbers..
Shrek, you have horrid numbers.. Most likely you are looking at a topend overhaul. With that much loss you will have turbocharger leakage issues from the possible blowbye. You cannot do a leakdown HOT on these engines.. Most are done cold..
Here's an old discussion on this:
https://rennlist.com/forums/993-turbo-forum/408730-porsche-leakdown-test-opinion.html
