Clutch Booster
After all the work, time and $ spent on my major engine and clutch overhaul I now find I need a clutch booster which is apparently fairly expensive. By any miracle does someone have one or know where I might purchase one at a "reasonable" price, thanks part # 99311623752
NP.
Make sure you get the right one. My shop ordered a brake accumulator instead of the clutch accumulator. They are hazardous materials and can't be shipped. That must be fun.
NoSubEDU could you pm me info on the brake accumulator? That is if you still have it,
brake pedal has begun getting spungey and going to the floor at inopportune moment
s,thanks Bert
s,thanks Bert
The part number you listed is for the slave cylinder. With all the stuff you have on your car, I would recommend dumping the power slave and just put in a standard one. You have to plug a line for the power clutch, but not a big deal. We do it regularly. Your clutch will be stiffer (more like a NA car with a RS setup). You are looking at around $950 for the slave and bomb setup (you always want the bomb when you replace the slave). NA slave is in the $150 range. Just a thought....
Great suggestion Bob, unfortunatly I already repalced the slave. Got a bit lucky - paid $700. Did also change the accumulator as well......
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
