Flexible turbo inlet pipes (or any aftermarket inlets)
Anyone have these installed?
http://shop.fvd.de/us/en/Porsche-0/9...90mmx60mm.html
I'm not an FVD fanboy due to their usual pricing but they did drop the price from $1,025 to $425 for a set and are realistically priced now imho. When I took the engine out I was surprised how constrictive the turbo intake pipe was on the passenger side (i think it was that side).
The big fear is that these things will collapse under boost with bigger snails so I'm wondering if anyone here with K24's or bigger have had any issues with these inlets. I also believe they are slightly bigger in diameter than the stock plastic inlets.
Thanks guys!
Thanks guys!
Those look pretty nice but worth 400 bucks? I wouldn't upgrade until you have some evidence that your current setup is not performing as expected. With that said, i'm still interested in seeing some data on those bad boys
I have those on my car. Certainly look much less restrictive than the stock parts and feel quite rigid. Pretty easy to fit (although the undertray needed trimming slightly on the upright parts for clearance). Would be difficult to see them start to collapse under boost without little cameras or similar.
Steve
Steve
Data? This isn't ME7 my friend your still spoiled but i can measure them and take fancy pictures to justify that 100whp. More importantly I can give you a butt dyno graph which clearly shows the increase in flow over the stock pipes
Give me a ring today I put together the BBS wheels last night and they are looking good!
I have not found any aftermarket hard pipe solutions. Seems most are custom made and incorporate some flexible connections in the design.
In the end, I went for the "Reinforced Pressure Hoses" (click here). When I got them, I could see FVD used the standard intercooler hoses which have been reinforced with Silicone. So far, so good and no sign of budging. I'm happy.
Till this day, the "Suction Hoses" remain a mystery and I have no idea whatsoever what they are for! It would be great if someone could advise...
Cheers
Ziad,
These are direct replacement for the plastic turbo intake pipes which connect to the metal Y pipe in the front of the engine. The Y pipe connects to the air filter.
Hope that helps![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Hope that helps
Hi Jean! I looked at these pipes initially thinking that they were a direct replacement for the intercooler hoses AKA as "Pressure Hoses". Upon further inspection I realised that these were called "suction hoses" and that they have different dimensions (590mmx60mm) to the intercooler hoses, which are 43 / 57 mm x 410 mm. So I was not sure what they were for as they also looked the wrong shape. In addition, there was nothing in the description that suggested they were flexible.
Cheers
Cheers
Check out the hoses on this thread here. They look like they can solve the problem... but the cost is on the high side for me personally.
Interesting thread again...
I can confirm that turbo suction hoses have to be done from something strong that can't collapse. My ECU programmer have seen on dyno when they drove JUSSI's (member from Rennlist) 993tt, that those short rubber hoses can collapse too (between factory plastic suction pipe and turbo). He also confirmed that those factory plastic suction hoses is bottleneck when you tune up your engine.
In my opinion suction hoses has to be done from carbon fiber. It can't collapse and it allows maximum inner diameter because of thin structure.
I have been searching the place and I found following company has done intake plenum for 996 but I don't know yet do they have solution for 993.
http://www.scargoracing.com/
If they don't have pipes for 993 I will make mould my self and give the work for local carbon fiber factory.
Maybe group order?
Maybe group order?
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
If anyone had an intake pipe system off their car, I would be happy to take a look at it with a view to fabricate one from ally.
