SHK 993tt 570PS
Rennlist Lifetime Member
Not that I'm doubting the the S wing produces more downforce but this is one of the few times I've seen this statement in print. Can you expand on where you read/heard this?
Hi Michael
Very interetsing thanks![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Your car is really light! I did a lot to mine and I am still about 40kgs heavier than you. I also did the roof change and bought a Porsche Gt2 roof all together. It looks like you have fiberglass rear fenders? Are your doors stock?
for better comparison, would it be possible for you to send me your 3 files in raw format? This way I can customize the view and superimpose data..
The best part about your car is that you have the stock rear wing, I simply love it.
For your coast down runs, you do not need to go all the way to those high speeds, it will be better, however a 200-180kph coast down would be good too. Also it will help if you do a 40-20kph coast down and record both runs.
For the test, I simply put the car in neutral, no clutch.
Jean,
the low weight might also have to do with the fact, that the car originally was a n/a car in which a turbo engine had been transplanted. (As a transplant surgeon I do love this procedure)
So , there is no front drive systen, etc. etc.
The front hood is made of alu, the doors are not.
The fenders are normal , I even had to do an additional kevlar isolation to the rear fender, because its so near (narrow body) to the exhaust components and melted away several times before that isolation.
In the interieur, front seats are GT3 seats ,the rear seats have partially been deleted, a small roll cage (in german : Überrollbügel) has been added.
I will send you the two files as PM this evening or tomorrow evening, the last two files are extracted from one run.
Yours
Michael
PS.: By the way: I do love your car also, and that since years already. It is the best example of how one can modify the aircooled twin turbo to a really "Newton" beast (5.6 from 100 to 200 right?)
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
Just to reiterate on what we know, Porsche stated zero lift for stock tt at 250kph (inferring lift after that speed) when the 993tt was introduced. Sport Auto measured 17kg lift at the rear in the Merc tunnel at 200kph (they didn't measure front numbers in those days) so do we believe SA ? Probably (that is what it feels like to me anyway
I am going for OEM GT2 wing next which (according to Ian Kuah) when set at its flattest position will give zero lift at the front with "some downforce" at the back (this is with OEM GT2 front splitter which it a bit different to my FVD jobbie but I'm hoping). The numbers obtained at 270kph with the 993 RSR wing set up which is pretty similar was 11.9kg rear positive downforce with the flat wing....
RS38, mw911
I will be in Germany July 25th-30th exclusively for car/racing related stuff, I would love to see some of these beasts in action.
RS38, you obviously seem to be close to 9FF, seeing that 993TT in person would be very interesting. I will be shuttling between Nurburgring and Hannover, passing by Verl at Konrad Motorsports so Dortmund (9FF) is on my way.
Let me know if this is feasible.
Cheers
Cheers
RS38, mw911
Cheers
Cheers
PM sent
Yours
Michael
[QUOTE=TB993tt;5557373]Michael, thankyou for sharing ![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Your acceleration is strong, 0-300kph in low 28s superb... I would love it if you could do a "coast down" run from high speed say 250+ to 180kph and let our gurus Jean/Juha crunch your aerodynamic data to see what improvements you have been able to make ?
Dear Jean,
via E-Mail I did sent You two files containing 2 different "coast down" runs (same part of the autobahn, first with tail-wind, second in the opposite direction, thus with head-wind), which I did this morning.
I wish you a great time on the nuerburgring next week![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Michael
Dear Jean,
Michael
I guess some of you would be interested in the following:
Having experienced multiple "pop offs" of my boost hoses at high peak boost I (and multiple other customers) convinced the SHK people to provide us with modified boost hoses.
These are made by the same manufacturer as the OEM ones but LONGER and with additional enforcements at the lower end (to eliminate the lower end popping off, which is, however, rare).
The theory is, that these hoses can be mounted with virtually no tension thus making "pop off" more unlikely.
At least fitment was perfect....
See the pictures attached
Michael
Michael
Why do I feel so left out!
Ok,
Me too i spose...![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Thanks\
Simon.
Me too i spose...
Thanks\
Simon.
Former Vendor
Pete
