Flexible turbo inlet pipes (or any aftermarket inlets)
I'm surprised there isn't all that much on this in the archives, those plastic intake pipes are aweful and there is huge room for improvement. The big engine build guys probably have one off intake pipes
cool new avatar Viggo... ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Bob's pipe's are turbo to I/C. These are suciton side.
Seems like the biggest challenge on the suction side are the clearance issues to get around suspension. It is a tight fit... but Jussi did prove there was a way around it (no pun intended) while increasing volume/flow.
Wish I would have sent you mine while they were off, Chris!
I didn't think to test the FVD pipes for collapse before I put them on, but they felt relatively stiff. As Chris says, would be relatively easy to test if the pipes were off the car. As they are under vacuum they can never see more than 1 bar pressure difference (and in reality they will always see a great deal less than this).
Steve
Steve
Steve
Steve
Thanks for your help
You might want to check this site. They have all sorts of tubing and the engineering specs are listed for heat resistence vacuum pressure etc for every product.
You just need to spec out which hose you need, the length and diameter at both ends, inexpensive and same or better result due to the flexibility that you have across the range of products to choose.
http://www.ducting.com/Air.html
You are right it is very confusing. I did not know they were different from "pressure hoses", they look the same. Did you sell the Motorsports intercooler hoses that you bought?
Looking forward to meet up again during the time trials in March.
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Jean
No I still have those... I've been meaning to post them on RL classifieds. Will do that soon.
That would be very cool. Looking forward to seeing you and try to get engine over to Julian fast, there's still time.
Hello Spartan
Install was very easy and have been running them for a few months without issue (will take some photos when the car is in the air again).
The upright parts of the undertray near the back wheels (near the front of the undertray) needed clearancing a bit to stop them rubbing on the pipes, but it is only fibreglass and cuts easily (I used an air saw and was finished in less than 5 mins).
best regards
Steve
best regards
Steve
Beautiful car BTW, I followed the build on the other forum, did you get a chance to weigh it? Any rolling acceleration runs to support the 850hp claim?
I would be interested to hear anyones experience w/ the fvd pressure side hoses. They claim to run them in high boost cars w/ no issues. I'm trying to avoid buying hard pipes, although it may turn out that it is the only solution. It seems like a simple problem to solve, just find a more robust hose that doesn't tear. I must be missing some thing.
ken
ken
