fellas, please help! i am freaking out!!! (long)
#32
Kevin,
I am trying to figure out if a turbo is blown. The car was overfilled as you said. I had the car towed, oil changed, drained oil tank, turbos and crankase, Porsche filters installed. Found a pint or less of oil in IC and a little in the throttle body. Cleaned everything as good as possible. Ran car, smokes less but still smokes and stinks. Driver tailpipe only. Saw a little oil coming out of that tailpipe too. Passenger side dry, no smoke, smells normal.
Pulled hose on cool side of passenger turbo. Some oil came out but compressor wheel (fins?) nice shiny silver. No oil in compressor housing to speak of either. Your previous posts say finding oil in that area is a good indicator of failure except in case of overfill.
Basically symptoms now are no smoke until exhaust heats up. Once hot, at little or no smoke at idle but smells horrible. On the highway when you come to quick idle after boosting, significant smoke for a few seconds.
How can I definitively tell if that turbo is bad or just burning off the excess from before.
Also, am I risking any other problems if I continue to test drive while diagnosing if the turbo is bad.
Last edited by badabing; 07-12-2010 at 01:08 PM. Reason: Passenger side dry, no smell (not driver)
#33
Badabing, I am writing a new article to post on Rennlist about similar issues. It is not GOOD to run the engine with it eating oil. Oil dilutes the octane rating and you risk detonation. Fouling the spark plugs is almost a given.
1) You didn't mention installing a new oil filter (first thing you need to do) Not the one with the oil change, spin on another one.
2) Pull the IC, and ALL the inlet ducting, they attach to the turbocharger inlets, Clean the throttle-body plenum.
3) Undo the turbo sump tanks and drain the oil out of them and tell me how much you drained out. Leave the plugs undone and report back to me, how much oil drained out of each side.
Lastly, failed turbochargers will smoke all the time, and in the beginning failure stages will fill the inlet side of the inlet piping. This will pump oil into the IC and intake.
#34
Thanks for the reply. A few follow up questions.
1) Both oil filters were just changed as part of the oil change. You are recommending changing the smaller one under the engine again, correct? For my own education, what is the reason behind this since it was just changed 50 miles ago?
2.) Cleaning the TB plenum...how should i do this? try and wipe the inside down with a cloth or use some type of CRC TB cleaner?
3.) Drain turbo sumps... Should I reassemble the car after steps 1 and 2 and run the car to operating temp before draining or should i drain as is and report?
#35
Kevin,
Here is a picture of what came out of each turbo sump. The cups represents the sides of the car as viewed from the rear. The left cup is the driver side turbo sump, the cup on the right in the photo is the passenger side.
![](http://c4.ac-images.myspacecdn.com/images02/114/l_7ec1ad11e4a241a7b6807b70520e33e7.jpg)
What's next?
Thanks for your help on this.
What's next?
#37
The oil will keep on flowing. Sample it at 4 hours and overnight.
The fault lies with your engine oil filter. The internal check valve is not seating. I have seen a migration of 8 qrts of oil over time.
Solution>> spin a new oil filter on the engine. Clean you IC, and your plastic inlet pipes to the turbocharger. You will have a 1/2 pint of oil in each compressor housing that you can't get to unless you unbolt the compressor housing.
#38
this is what came out over 4 hours after having already been drained initially and then drained again after 1 hour.
![](http://c1.ac-images.myspacecdn.com/images02/151/l_c3d92989ab774e808c1e5153906f8378.jpg)
seems driver side turbo is accumulating at a faster rate even though it is the driver side tailpipe that smokes
#39
![](http://c4.ac-images.myspacecdn.com/images02/103/l_4cf94fce722d4f5bb2e8bde9ad60a5b3.jpg)
a new porsche filter has been spun on to hand tightness. the sump plugs have been replaced but engine has not been cranked. I will leave overnight and remove sump plugs and post what has been accumulated overnight
#40
![](http://c2.ac-images.myspacecdn.com/images02/113/l_a3f6d87525864936812bd43438c70f7d.jpg)
this is the total flow since the sumps were drained including the overnight. if you compare the difference from the previous picture, you can get and idea of how much accumulated overnight even after spinning on a new filter and not having cranked the motor at all.
is the check valve on the new new filter not properly seated either? how are you supposed to get a proper seat. is it too tight? not tight enough?
#41
#42
The original incident 2 years ago was due to a mahle filter. This time it is either due to overfill or failed turbo. That is what Kevin and others are helping me work through.
I have received some PM's stating that this thread is helping others with similiar issues so I will continue documenting this issue until it is resolved.
Thanks for everyone's input so far especially Kevin.
#43
You might want to invest in some of these..... Kevin has some and I highly recommend it: The silver lines are stock, you want the green lines:
https://rennlist.com/forums/attachme...-lines-001.jpg
and these:
https://rennlist.com/forums/attachme...-lines-002.jpg
and these:
#45
the car has just been sitting for about a week. i wasnt really sure what the next step was/is after measuring the oil coming out of the sumps.
i've put everything back together and it has been started about twice per day (car is at my friends shop who is helping me with this, need to move it in and out every day).
i am going to swing by and pick it up today and see what's going on. in the meantime if anyone has any recommendations as to what the next step is i am all ears.
right now i feel hesitant to drive the car for fear of detonation or other damage as Kevin has warned because i am not sure if either turbo is bad.
