Speedline 993 RSR wheels
Guys, several of you TT owners are considering making GT2s and move your car to another level.
I have seen pictures, and have a set of 993 RS wheels here for restoration and several wider than stock inner and outer rim widths.
I do not have a TT, nor do I have access to one with the GT2 bodywork, but here are some pictures of a test set of rear wheels that might answer some of the questions I have been fielding concerning proper widths and what it will look like.
The car in the picture is a 993 regular body, that is ready to have TT rear quarters welded on.
Wheel size in the picture is 12" -- which is the size it seems most everyone is asking about.
It is a 6.5" inner hoop with a .25" crush and 5.25" outer rim. If that is not wide enough I have a pair of 6" outer hoops that would make a 12.75" or by changing the inner hoop to a 5.25" with the 6" outer plus the crush it would be 11.5" but would stick out 3/4" further from opening of the fender.
Fronts could be sized to 8.5, 9, or even 10" depending how aggressive you want to be.
805-498-7261
Jim
805-498-7261
Jim
Jim , I came upon a set and have extra parts...looking for how to order or obtain
bolts and nuts and need one 3.5-4 inch outer.
Believe I have 8.5 and 10.5 but as mentioned want to go 12.5 rears, thanks Bert
ecrobinson1726@msn.com
Why do I feel so left out!
Jim,
PM sent.
Simon.
PM sent.
Simon.
