Fabspeed Motorsport's *New* Maxflo Mufflers & Sportcats/Catbypass Pipes
That clip at the bottom of the first page is old and is one that used to be listed on the Fabspeed website as the "Maxflo Mufflers combined with the 200 cel cats."
Joey, do you have a current clip of the new muffler combined with the catbypass pipes?
I spoke with ?? at Fabspeed who said our tt engines do not need very much in way of muffler because our engines are low compression which means softer combustion. This makes sense. I guess a good resonator paired with our turbines ability to attenuate sound are enough to give a decent growl and be less restrictive and lighter than stock.
If I can fit this system into my car I'll have a pair of TechArt muffs (the ones used for the 3.8 Andial conversions) for sale. I was holding on to them in hopes to cut and plate them to make them fit my fenders one day.
I have been waiting 2 years now since we (I and Chris from Turbokraft) made first complaint about this. I have written to you many times after that but no any answer.
![](http://www.munkuvat.org/kuvat/100014.jpeg)
Rennlist Lifetime Member
The turbines in the exhaust do seem to blend the noise pulses together a bit, particularly under load, but our engines are still very capable of producing a large volume of noise.
I went through probably four sets of FS mufflers and was never happy with the fit. I did find the customer service to be fairly good though.
I am very happy with my FS MBPs.
Basic Sponsor
I've never received an email from you at my location, maybe you sent emails to other addresses here at Fabspeed. Please email Joey@fabspeed.com and I'll resolve this issue with the headers.
Jussi,
HI Jussi
This is Joe @ Fabspeed Motorsports and I design and test all the products at Fabspeed Motorsports.
Why in the world would you CUT-OFF and remove the stainless steel heat ducting/ sheetmetal on your Fabspeed Motorsports 993 Twin Turbo headers? It does not make any sense whatsoever for several reasons.
You mentioned that you have had those headers on your car for over 2 years and your 993TT makes BIG power and runs great. Why would you take it upon yourself to CUT something up.
From the yellowed stainless steel condition and other big blue boost hoses and other modifications.......obviously our 993TT headers have worked great with your 993TT performance build-up & tuning package that you have assembled. Your car is not a concours stock car.
We have built and supplied many 993Twin Turbo headers with heat and without heat to 993TT owners worldwide and to many engine builders that use Fabspeed 993TT headers for Twin Turbo engine conversions for any aircooled engine case.......we have NEVER EVER had 1 complaint.
Furthermore ANY and ALL 993 non turbo and 993Twin Turbo factory rear OEM Porsche engine undertrays should be tossed in the trash with no emotion as these undertrays are 100% junk and all they do is make a HOT aircooled engine even hotter. The engine undertrays BAKE the intake and exhaust valve guides with extra retained heat.........the guides get smoked and beat-up and the engine wears much faster. Top end rebuilds for aircooled cars are very expensive and 993 and 993TT seems to need alot of these without high mileage.........eliminating heat is the way to go.
Removing the 993 engine undertrays is one of the 1st things any Porsche enthusiast does to save weight and allow the engine run alot cooler. Significantly cooler. Porsche factory 993TT and 993 race cars never used this undertray.............so aerodynamic stability and SWiss noise regs.......dont add any credibility.
Our headers have much more streamlined and radiused primary tubes and a high velocity merge collector for a major improvement in power and faster/ transitional boost. They work great and we cant compromise power to maintain a engine undertray that only offers a faster wear-out date for all 993 engines. Unless a 993 is a concours car.......... all 993 engine undertrays should be discarded. The factory headers are squashed down and have a flat collector and everything is a 400HP compromise.
JUSSI-- if the undertray was important to you for some reason after 2 years............ then the undertray which is made of Fiberglass should have been CUT and clearanced to clear the Fabspeed stainless steel performance headers. This would have been a 30 minute job and infinitely easier to do and allowed the power to remain the same.
A simple solution at this point is to have someone in Finland take the headers and have their BOTTOM stainless covers welded back on. This should be simple and easy to do and you can cut-up the heat shields.
Have a great day.
Joe Fabiani
Fabspeed Motorsports USA
Have a great day.
Joe Fabiani
Fabspeed Motorsport USA
155 Commerce Drive
Fort Washington, PA. 19034
www.Fabspeed.com
P: 215-646-4945
F: 215-646-9828
Exotic Car Performance Experts
Porsche, Ferrari, Lamborghini, McLaren, Maserati, Bentley, Aston Martin, BMW, Audi and Jaguar.
31 year PCA Club member supporter
14 year Ferrari Club member
1st ever financial supporter of Porsche Fans/ Rennlist
155 Commerce Drive
www.Fabspeed.com
P: 215-646-4945
F: 215-646-9828
Joe,
I might not like your intervention but you certainly have the right to defend your product so I fully respect that..
What I DON'T LIKE IS THE FACT THAT YOU SAY THE TRAY IS JUNK! HOW CAN YOU SUPPORT SCIENTIFICALLY YOUR ARGUMENTS? THIS IS NOT ONE OF THE FREQUENT PROBLEMS THAT AIRCOOLED OLD PIECE OF CR@P 993s HAVE IN THIS PART OF THE WORLD WHERE WE RUN IN 120F.
IF I MAY ADD THAT ALL THE 993GT2 EVO RACE CARS HAD ENGINE UNDERTRAYS FOR AERODYNAMICS IN ENDURANCE RACES.
![soapbox](https://rennlist.com/forums/graemlins/soapbox.gif)
Ok now I feel better.
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Have you seen what he's done to his car???? I believe he'd get his right hand replaced with an angle grinder if he could!
..Why in the world would you CUT-OFF and remove the stainless steel heat ducting/ sheetmetal on your Fabspeed Motorsports 993 Twin Turbo headers? It does not make any sense whatsoever for several reasons..
JUSSI-- if the undertray was important to you for some reason after 2 years............ ..
I bought these headers march 2006 and installed them summer 2006 and right after that I told to Chris (@Turbokraft) that these headers are done with wrong mold. He made a complaint to you(Fabspeed) and nobody ever replied. Then I wrote myself to you after that, maybe half year later but nobody answered again. Then I wrote email second time from this RL forum. I dont remember actual date but about year ago. I have already cleaned my sent email files but administrator could check that from backup tapes if you like.
Anyway the point is that we have written to you(Fabspeed) three times during 2 years and just now, at fourth try you (Joey) replied here !
And your original question, Why did I cut?
I answer: I cut it because you haven't answered anything in a year and I wanted to install undertray shield for MOT inspection. Tuning a car in Finland is forbidden and that shield prevents from inspection's eye quite efficiently.
So I thought that ONLY heater box would been welded too low and if I cut that off I could install the undertray shield for MOT inspection.. but no, also pipes run too low as you see from pictures, so I cut that heater box off for nothing.
I dont use that shield for every day driving - only for that one day per year (=MOT inspection).
I would like to make a better aerodynamic undertray shield from aluminium if that left header would locate upper just like the right one.. but that is another story.
My opinion is that you should admit your mistake and send properly made left header without any cost.
I'd also be interested in a set of Fabspeed headers if a new model is made that allows the left hand shield to fit (like the right hand one). I don't want to leave my shields/undertray off.
Steve
Steve
Mr Fabspeed, you are on a forum where several contributors take very high speeds in their 993tts quite seriously and despite the twaddle and popcorn debate which may have occured over the years on the 993 board about the efficacy of the undertray some of us have a real vested interest in whether the undertray is "100% junk" and "trash".
Smooth airflow under a 993tt is pretty important over 120mph and at 190mph it makes a big difference. People who have tested at these speeds are in a position to make informed opinion - you I think are not ?
Jussi drives his cars at these extreme velocities and your ignorance is very disturbing and potentially disasterous, do not preach garbage about stuff of which you know only anecodote and myth.....
