993 Turbo Forum 1995-1998
UMW stage 2 kit - up and running at last :O)
Old 03-28-2008, 01:21 PM
  #31
Jean
Jean's Avatar
Great display of data! Thanks Ace and Phelix for sharing all this. 6-8 deg. C still in the UK? we're seeing 36C today!
Edit: The long Gs data (acceleration) has a problem, the numbers are not realistic.
Old 03-28-2008, 05:22 PM
  #32
sfbanchs
sfbanchs's Avatar
9.9 s 60-130 is faster than an F430 (~10.5s)
Do you know what a stock c6 z06 does 60-130?
just curious
Old 03-28-2008, 06:41 PM
  #33
TB993tt
TB993tt's Avatar
The long Gs are much too high for the acceleration aren't they ? I don't have my data to hand but the numbers looked higher than what I have seen on mine
Old 03-29-2008, 12:04 AM
  #34
Jean
Jean's Avatar
Yes extrapolation of acceleration shows that the car has more hp and torque than TB993TT and much higher than Phelix or Bill S. (60-130 in 9s.), looks like around 600hp. The speed vs. time does not reflect that however, to be accurate.
I do think that the car should be running less than 10s especially in that cold, so it is realistic, however with the above in mind and a top speed of 126mph only, I would do another run to confirm and get more accurate data for proper analysis purposes (boost vs. torque vs IAT).
Old 03-29-2008, 06:04 AM
  #35
ACEparts_com
ACEparts_com's Avatar
Unfortunately I'm in a different country to my car :O(
Old 03-29-2008, 09:07 AM
  #36
malcolmd
malcolmd's Avatar
I had thought that the consensus was that Bill S's RUF TurboR had a conservative 490-500 hp, with times in the mid 8's, Toby with a bit more, and Phelix speculating at around 470 with the UMW Stage 2 with the 1.35 bar max boost program.
Old 03-29-2008, 01:44 PM
  #37
Kevin
Kevin's Avatar
Ace's software that is loaded in his '96 ECU is not Stage 2. It has been modified to reduce boost, the timing map has also been altered.
Old 03-29-2008, 02:37 PM
  #38
bb993tt
bb993tt's Avatar
Originally Posted by TB993tt
Minivmax part deux
Can I come out and play too? I need to, ahh, gather some data on the new motor.
Old 03-29-2008, 05:37 PM
  #39
Barney1
Barney1's Avatar
The 60-130 times are done in what gear??
Old 03-29-2008, 06:31 PM
  #40
bb993tt
bb993tt's Avatar
Rolling start in 3rd ... end in 5th. Two shifts with our cars.
Old 04-01-2008, 11:01 AM
  #41
gary11
gary11's Avatar
Default WOT
fogive my stupidity wot does the abbreviation WOT mean?
Old 04-01-2008, 11:04 AM
  #42
bb993tt
bb993tt's Avatar
Wide Open Throttle, wot?
Old 04-01-2008, 03:42 PM
  #43
ACEparts_com
Well as there's so much negativity going around the tuning scene I will sum up that i'm as happy as a happy thing on prozac. Sub 10 seconds 60-130 kind of confirms my buttometer reading of 10-15% which makes it the tuning bargain of the century I think..
Cost break down for anyone in the UK
Turbos, ECU & lots of bits like MAF etc. APX £4000+vat
Cats & new exhausts £1000+vat
Installation £750+vat
Plus a load of bits which drop off that may/may not always need doing £500
Diamond ring for the other half £7500 (what I blow on the car I had to blow on her too)
So all in £6250+vat.
Old 04-01-2008, 03:52 PM
  #44
vincentdds
vincentdds's Avatar
Fast car and happy wife. What more can you ask for?
Old 04-01-2008, 04:10 PM
  #45
ACEparts_com
Not married so even happier!
Ps Big thanks to Kevin for answering 64000 emails and calls. Top service all round really.
Quick Reply: UMW stage 2 kit - up and running at last :O)
