993 headlamp adjustment
need to adjust my h/lamps do you need to remove them or do you use the little holes with rubber grommets in inner wings,any help would be good thanks chaps
thanks phelix search is indeed our friend (I am just lazy)
nb does one adj do hi and lo beam>or are there two allen bolts,
does not mention on threads i found by the way
still need help cant see any oval plastic thing just a couple of grommets perhaps the allen bolts are behind them?or there is aplastic clip with two 10mm bolts which appears to hold headlamp removal arm in place,a pic would help as ive no handbook.
thanks a lot chaps
thanks a lot chaps
Lift this little rubber tab up.
There are two holes where you can insert your Allen key to adjust.
Top one [from memory] does low beam
![](http://www.qsm.com.au/q/post/adjustment_1951.jpg)
With the headlight removed, you can see what you are inserting the Allen key into:
![](http://www.qsm.com.au/q/post/adjustment_1971.jpg)
Why do I feel so left out!
Q,
You're back!! How was the trip? Buy any new cars?
PM sent!
Sorry for the hijack![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Simon.
PM sent!
Simon.
Rennlist Lifetime Member
