993 Turbo Forum 1995-1998
Porsche Leakdown Test Opinion
Old 02-10-2008, 01:00 AM
  #46
TT Surgeon
TT Surgeon's Avatar
Originally Posted by 993TurboS
So, doesn't a top end rebuild cost something like $10k? And isn't it the case that, after a top-end, you can be pretty confident that the leak downs will be <5%? So, why $45-50k for a high mile car, if what you are worried about is the leak down? If I have a 60k mile car that I have kept in as-new condidtion, but has a leak down of 12%, to me, that car is worth $60k still if I know that I can get it to <5% and get 60k more miles out of it for $10k.
Let's be real, 10k is a decent amount of change, but the variability in prices on these cars is like $45k - 95k. What is a a top end rebuild in that range? Squatola. 20% of the variability.
Perhaps there is something that I am missing, but if it is true that a top end rebuild can assure a low leak down, and it costs only 10k, then I say big deal, I am going to care more about how perfect the car looks, and pony up the 10k to fix the leak down after the fact.
Sounds reasonable, but I think a top end goes a bit deeper than 10k, more like 15-17k I think.
Old 02-10-2008, 01:07 AM
  #47
Kevin
Kevin's Avatar
It's cause and effect, valve guides within spec, will keep the valves on there seat margins with very little leakage. Worn guides do not allow the valve to be concentric and run tru in/on the valve seat. As this happens the seat and valve margin (surface area where the seat and valve touch) get pounded out, with no consistant or tru contact 360 degrees around the seat, the valve runs at hotter temperatures. The heat generated causes metal fatigue. You then lose the valve head (extreme case).. When the margin is beat out due to the valve not being able to run tru in the guide bore. Combustion chamber gases leak past the valve seat when the valve is closed.
Mark, I mentioned the oil consumption as a secondary effect. If you are doubting the leakdown numbers (from your mechanic) and want to have a visual check, drop the heat exchangers and check the condition of the valve guides/valve stem in the exhaust port.
Old 02-10-2008, 10:24 AM
  #48
993TurboS
993TurboS's Avatar
$17k is a somewhat different story. I read elsewhere on RL that is was 8-10k. I guess the question is : if you are about to sell your car, and all you care about is getting a low leakdown, how cheaply can you do it and get to 5%? Because that is all a leakdown test is showing you. If that costs $17k, then I might be getting on board. At $10k, not so much.
Honestly, though, even at $17k, there are other factors that are nearly as important to me. For example, I'd be willing to pay more than that to get a moderately personalized 993TT back to originality. So, for me, to bring a car's mechanicals back to 100% might be a lot easier than dealing with other issues.
I think the answer to this question depends on a lot of things, like 1) how much will you be driving it? 2) how will you be driving it? 3) how long will you be keeping it? 4) how much do you care about the sofer issues like colors, condition, etc?
The market is pretty small for these cars. It is often not possible to find exactly what you are looking for. If all you care about is getting a car with <8% leakdown, then okay, you probably can find one for less money than one with a 12%, but what if that 12% car is really the car that you want and would love? Pay the 10K and get what you want, I say. For me, not having certain options/colors was worth 10k, because I didn't want to have to go out to the garage every day for 10 years and see ____________(color omitted to avoid offending anyone).
Old 02-10-2008, 11:36 AM
  #49
mpgandco
mpgandco's Avatar
I am a newbie to Turbos.I thought a Top End rebuild on a NA car was around 6 to 8k.Is a Turbo that much more work than a NA car?As far as I know you just have some extra parts to remove,like Turbo's and such.Is it the fact that it is a Turbo and therefore the price doubles?Or is it that Turbo parts are a lot more expensive?
Old 02-10-2008, 11:46 AM
  #50
MarkD
MarkD's Avatar
yes, $6-8K is more like reality. At least my reality. YMMV. I think $6K is kinda optimistic unless you are doing the drop and teardown yourself.
Of course, this does not include the "while you are in there" stuff.
Kevin,
I don't doubt "my mechanic"... though I do argue with myself at times I am getting professional help with that.
My only point was that guides themselves are not a primary factor in leakdown. You stated cause and effect. Exactly.
Old 02-10-2008, 02:35 PM
  #51
TT Surgeon
TT Surgeon's Avatar
My friends was 16,500 last yr at manhattan porsche, 97 993tt 48k miles.
Old 02-10-2008, 04:20 PM
  #52
MarkD
MarkD's Avatar
well, I really hope he got more for that price than a top end rebuild.
Old 02-10-2008, 05:02 PM
  #53
Kevin
Kevin's Avatar
On a good day a Turbo topend is going to cost you around $7,500.. If you need one cylinder head add $1,800.00 (each) If you need pistons and liners add $5,200.00 Some of these cars that I am seeing need one or two camshafts due to scuffing and pitting on the lobes. Most will address the turbochargers. Then you need to add $1,200 for new hydraulic lifters, toss in $340.00 for replacing a few rocker arm shafts. When you are done you are in the range of $12 to 15K..
Old 02-10-2008, 07:54 PM
  #54
TRINITONY
TRINITONY's Avatar
So a 60k car can easily become a 75k car.. the 996TT suddenly becomes more attractive....now back on subject.
Old 02-10-2008, 08:24 PM
  #55
MarkD
MarkD's Avatar
yep, it can ALWAYS cost more. but...
Old 02-11-2008, 12:27 AM
  #56
Jean
Jean's Avatar
While you are in there you can twin plug your heads, you can also change the suspension and upgrade for some Moton , don't forget the Sport Cup tires, 6 piston brakes etc... about $20k all together..
I think we are going too far in this??
Old 02-11-2008, 05:47 AM
  #57
TB993tt
TB993tt's Avatar
Originally Posted by TRINITONY
So a 60k car can easily become a 75k car.. the 996TT suddenly becomes more attractive.....
Is this supposed to be a joke - you would buy a 996tt over a 993tt
Old 02-11-2008, 11:24 AM
  #58
Turbodan
Turbodan's Avatar
more attractive to the wallet. great car but not visually as appealing as the 993's!.
what was porsche thinking with those teardrop headlights?
Old 02-11-2008, 03:15 PM
  #59
lucycan
lucycan's Avatar
And the Ford Escort interior!
Old 02-12-2008, 06:02 PM
  #60
Kevin
Kevin's Avatar
For the guys that want to do there own work..
http://www.xs11.com/tips/misc/misc3.shtml
Quick Reply: Porsche Leakdown Test Opinion
