Help with 993tt engine install into a 930
#31
It allows higher revs without breaking down. The lifters are terrible for a higher rev motor as the tappets just can't keep up and break down. The down fall is it is a bitch to adjust the valves on the TT motor with everything in place but on a higher rev motor it is a must.
Isn't it to do with getting cams with radical combinations of higher lift/longer duration (like the EVO M64/83 cams) to work with the hydraulic mechanism reliably ?
Veterans may remember this thread
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
https://rennlist.com/forums/showthre...ight=hydraulic
#33
Not Forgotten
There has been a hint of it having Schrick cams, i guess they would need to be removed to find out? Or is there somewhere i can look with them fitted that will tell me something?
Thanks for the info guys, good link TB cheers, I take it your car has the hydraulics?
#34
Mine has had two different types of hydraulics (stock and 3.8RS N/A) and currently runs an iteration of the EVO M64/83 cam which is mechanical....
#35
Here's a 993TT in a 964....this was a very long project. Got all my upgrade bits from Kevin however and pleased with them. The car is brilliant, but I don't think I'd do this again...way too long not having a car, lots of $$...and did I mention a long time not having a car?
If you want to go this way, try and buy one done already. They are out there, which only proves I'm not totally insane.
#37
#41
I think there is a deal where you use the 964 cam sprockets...for more accurate timing, and when you do that on the TT you should also switch to the solid lifters. Ask Kevin, he can tell you.
#42
Right now the car is just staying warm and clean in the garage hiding from all the snow and salt. So no changes really, just hoping for a clear dry day sometime soon so I can go drive it. I'm in contract for a bigger garage (with a bigger house attached
) which will give me some more room to tinker, but everything else has pretty much been on hold until that plays out.
#43
I'm Still Jenny
I thought the 964 sprockets were only for early '95 cars which were fastened differently. I recall Later 993s going back to the 964-style sprockets?
#44
Being an early 95 originally NA car, my car does have the 964 style cam sprockets from the factory (still held in time by friction, without pins), it still has the factory hydraulic lifters as well. The 964 sprockets (with all of the other parts needed) will certainly make setting the cam timing easier since I don't have the Porsche cam/crank locking tools needed to set the timing otherwise. And yes, when setting cam timing with the 964 sprockets by the traditional method you need to use a couple solid lifters, even if only temporarily.
#45
Not Forgotten
I didn't want to start a new thread for such a simple question but i was hoping someone could answer this for me.
My 930 has brand new standard 930 fuel pumps fitted which have just been tested today and are delivering 1.2ltrs of fuel every 30 seconds (roughly 144ltrs per hour) and the running pressure is 4.4bar.
The 993tt engine is fitted with orange injectors and a 5.0bar fuel pressure regulator, can anyone tell me if the pumps are going to be OK for this set up, i'm picking the car up tomorrow to take to the tuners for mapping and i didn't want to waste my time if it needs bigger fuel pumps, also if there is anything else that could be an issue with this combination of components.
The car "should" produce something in the high (ish) 400bhp region, it would be good to hear what power you guys think it will produce and i'll post the graphs when i have them, the mods i'm aware of are as follows
K16/24 turbos (these are modified units with the hot side ported among other tweeks) with upgraded actuators
Evo BOV's
Solid lifters
Sport cams
Orange injectors
5bar regulator
Cat and muffler bypass, standard headers
K & N air filter
The engine will be mapped at Fearnsport, no fixed boost, but i've asked them to squeeze every available ounce of power they can but to keep things safe too, i'm guessing 1.0bar at WOT but short bursts above that in the midrange. What do you think?
Most importantly can someone answer the main fuel delivery question, thanks chaps
It's almost there now and i'm getting a little excited
Evo BOV's
Solid lifters
Sport cams
Orange injectors
5bar regulator
K & N air filter
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
