Frankenstein's monster is alive
#61
When trying to go very fast, front spoilers of many cars are taped for minimum amount of air holes (and Cd), like that world fastest car on ice (recorder in Finland btw )
see pic:
the car that goes fast on ice
and see vid:
over 200mph on ice
Toby: little more offtopic, do you know that company or guy, what I wrote about that Carbon Roof topic. That guy lives in UK and has special CF Porsche..
#62
Platinum Dealership
TB- I applaud the effort and don't mind the immediate front as much as I feel the design language of the GT fender flares contradicts the inward cuts of the 997 bumper adjacent to the fender/wheel wells. if there was a wider section to cover up the offset of the front wheels, that would be cool- but my favorite looks for the 993 are in no particular order:
turbo s chin spoiler , with techart or like-wise brake duct holes
gt2 front spoiler lip with wing things (jjayb's car has this) and brake duct holes
Ruf front bumper with additional custom front rubber extension (someone has this on their yellow ctr2)
cheers for the effort, but I vote for your old look! you have a beautiful and unique beast.
#63
The front tire exposure looks similar to my stock front end with 235 tires. Your inner fender problem certainly would cause lift, as the wheelwell would have some serious pressure build up at speed.
#64
Wheel arch wells are sealed, new SO2 N2 PPs are on @ 38/46PSI, PSS9s on full stiff at the back and hopefully a new engine undertray will be on tomorrow
#65
#66
Just the stock one - I read all the stuff on here and elsewhere and am pretty sure that for speeds over 200kph it is beneficial in the undercar airflow...... There were some patents filed by Porsche when the 993 was developed and it seems that getting a combination of flat under engine / box and maintaining proper cooling using available airstreams was a pretty tricky business and one which Porsche took very seriously....
#67
#69
So, if I'm converting properly (and understanding properly), at speeds in excess of about 125 mph you're better off keeping the tray on? And by "better" I mean even though it weighs a couple of keys and contains heat a bit more than not having one on? Enquiring minds want to know.
Containing the heat is not something I will worry about, "if" it causes premature valve guide wear then I will just get it fixed when and if it happens - with my engine it will doubtlessly be out for a rebuild of other wearing parts before that happens anyway
Originally Posted by Phelix
Somewhere in the 993/tt shop manuals it very emphatically states that the car should not be road tested above x mph without the engine cover in place. I think x is 90 mph.
#70
#72
What is funny is the countless threads on the 993 section with claims and counter claims with those advocating the tray/cover is there for swiis noise regs "because a Porsche rep/eng/tech told me so" -If it is stated in the manual as above then that is proof enough for me
Tray is on and the car felt oh so stable on the way home at 110mph
#73
Thanks for taking the time to dig that out
#74
And I will be pacing up and down awaiting the results. My car is READY!
#75
I think that this new front spoiler doesn't give any advantage for high speeds because it has so huge holes at front.
see pic:
and see vid:
over 200mph on ice
see pic:
and see vid:
over 200mph on ice
