Spark plug change
Yes, it is.. Depends on how good you are at bending your fingers and hands at right angles.. Cylinders 1 thru 3 15-30 minutes.. Cylinders 4 thru 6>> Have fun.. Hour to 2hrs with some skin removed.
Don't know on how many I am running now, but I sure know at least 2 or 3 are not operational, but you don't even notice it..
Let's say that I would expect the UK bill for one complete spark plug change for TB993TT to be around 2500 USD including cost of 12 plugs
For the infamous plug#6 you should remove your passenger rear wheel and take off the access cover from the engine tin. Following Porsches directions on this really made it easier for me. I assume you already know this but...
You may need to get creative with the tools. I ended using someone else's trick and took a T-handled spark plug tool, cut off the T and filed 6 flats onto the shaft so that it would fit into a 7mm allen/hex bit holder. The universal joint is taped over with duct tape to give it flexibility but still some rigidity. The frame rails mean conventional tools are not easy to use.
