993 Turbo Forum 1995-1998
mobil 1 15 50
Old 08-07-2007, 12:15 AM
  #46
Wilder
Wilder's Avatar
Received 5,041 Likes on 1,794 Posts
Originally Posted by Basal Skull
I didn't realize how good things are here interms of oil prices/grades! Now, if I can only find a place in Vancouver that carries Castrol SRF brake fluid - I end up having to pick up my brake fluid in Washington!
What's wrong with Super Blue?
Old 08-07-2007, 01:41 AM
  #47
ttAmerica RoadsterAWD
ttAmerica RoadsterAWD's Avatar
What about M1 5-40? Saw some fully synthetic M1 5-40 for "turbocharged diesel trucks" Guess it's formulated for diesel and not for non diesel?? Does it matter??
Old 08-07-2007, 02:29 AM
  #48
Doug Hillary
Doug Hillary's Avatar
Smile
Hello tt,
this lubricant is not on Porsche's Approved List as it is a "mixed fleet" Heavy Duty Engine Oil (HDEO) and consequently has not been tested by Porsche
It is MOST suitable for use in your engine!!
See the 12 Used Oil Analysis (UOA) reports on my 929S4 by searching for "Oil Condition Reports" in the 928 Forum here
It is one of the best lubricants available from any source and at any cost - it is a Group 4/5 formulation (with around 20% ester content) and has been on the market for nearly two decades
I have almost 10 years and many millions of kms experience with this lubricant in both cars and in my 500hp Detroit Diesel Series 60 powered heavy trucks
I use it in my Boxster and it will be in my CLK soon too
Regards
Old 08-07-2007, 03:09 AM
  #49
Jackpot!!
seriously, have you or anybody seen this: http://www.lnengineering.com/oil.html
What do you think??
Old 08-07-2007, 03:33 AM
  #50
Doug Hillary
Hi tt,
yes, and a search of the 911, 993 and 996 Forums over April and May 2007 will produce a wealth of discussion on the matter of lubricants. Research unless it is done "clinically" and with "all of the doors open" is always challengeable - but it is well worth reading. Genuine peoplewill always produce food for thought and present a platform for discussion
Regards
Old 08-07-2007, 12:36 PM
  #51
911/Q45
911/Q45's Avatar
Just to stir the pot, I believe any oil will be fine with frequent changes including filters. It is the simplest "mod" that anyone can do, hence the four pages of discussion.
Old 08-07-2007, 01:29 PM
  #52
MarkD
MarkD's Avatar
Originally Posted by Doug Hillary
Hello tt,
Regards
I had seen this when searching for 5w-50 and dismissed it assuming it was a no-go for these cars... glad you asked tt!
Doug, how much do we give up at the higher temps comparing 15w-50 to the 5w-40? In a 100F climate, how much do I lose? Negligible?
Basic question I know... please keep it in laymen's terms if possible
Also, just to be clear, this is what we are talking about, right?: http://www.mobil1.com/USA-English/Mo...uck_5W-40.aspx
Old 08-07-2007, 02:48 PM
  #53
jmayzurk
jmayzurk's Avatar
FWIW, I just switched to AMSOil TRO 20W-50 in my 993tt. I'm in Southern California where the ambient temps are rarely below 60F.
I switched from Mobil 1 15W-50 due to the reformulation (reduction of ZDDP) and the fact that I can't find it anywhere. I bought four gallons of TRO for $110.
Old 08-07-2007, 04:18 PM
  #54
Doug Hillary
Smile
Hi,
Mark - in simple terms the reduction in HTHS viscosity (@ 150C) is from 4.2cSt (M1 5w-50) to 4.1cSt (M1 TDT 5w-40) - very little indeed!
Regards
Old 08-07-2007, 04:39 PM
  #55
Kevin
Kevin's Avatar
What's the start up viscosity at 25-30C. It would be nice to compare the data sheets thru the start up operating range..
Here is a good thread that one can get buried in for awhile.
http://theoildrop.server101.com/foru...rue#Post886906
Old 08-07-2007, 05:07 PM
  #56
Doug Hillary
Smile Viscosity comparison
Hi Kevin,
I have a viscosity calculator and as you will see the 5w-40 lubricant is a little more viscous than the 5w-50 version at some points
@10C = 453cSt v 523cSt (5w-40)
@15C = 341cSt v 380cSt (5w-40)
@25C = 200cSt (est.) v 213cSt (5w-40)
@40C = 105cSt v 102cSt (5w-40)
Regards
Old 08-07-2007, 05:12 PM
  #57
Hi Mark. Yes, that's the one. I saw lots of it at Wallyworld (Walmart).
Old 03-20-2008, 06:54 AM
  #58
ruffy
ruffy's Avatar
hi sorry to beat a dead horse here
i came by this product today...
mobil 1 Turbo 15w50
doug? comments?
another was motul 300V (motorcycle oil)... any thoughts on that?
Old 03-20-2008, 07:16 AM
  #59
Doug Hillary
Hi,
ruffy - I am reluctant to Post more on lubricants here because of the incredible amount of misinformation around
Mobil 1 15w-50 in any current formulation are all suitable for use in your car if you wish to use something not on the Porsche Approved List. It is a shame you cannot buy the Approved M1 5w-50 there
Mobil 1 Turbo Diesel Truck 5w-40 or Delvac 1 5w-40 (now called "ESP") would be what I would use in such as car if I owned one! I use it in my lowly Boxster!!!
Motul products are about line ball with many others - the V300 version in the correct viscosity is a robust product when changed at shorter OCI's than those nominated by Porsche. Their formulations and quality are both excellent
Old 03-20-2008, 09:08 AM
  #60
ruffy
ruffy's Avatar
thanks doug.
living in these parts (singapore) makes it extremely hard to source for oils that NA sees.
ive exhaustively searched auzzie for anyone willing to export mobil vtwin... but again to no avail.
its SO frustrating.
To qualify my concerns, I am one of such owners that has experienced scored cams and premature valve wear. It was a costly affair.
I track my car, and i drive her hard....
appreciate your input and most likely will go for the m1 turbo diesel truck (assuming i can find it here)
motul will be my last option should all else fail.
thanks again for your invaluable insight
my name is chunn.
a pleasure to meet you
Quick Reply: mobil 1 15 50
