993 Turbo Forum 1995-1998
Price of new clutch for 993 TT?
Old 05-08-2007, 09:44 PM
cesar
cesar's Avatar
Default Price of new clutch for 993 TT?
I did a search and couldn't find anything except one where Viper Bob said the parts alone were $2,200.00 but in that post I believe the engine was already out so the labor would be less in that case.
Any idea on the price of stock clutch job at an indie or dealer for the 993TT.
I'm curious what the cost would be to pull out the engine, install stock clutch, etc.....
Just want to be prepared.......
Thanks!
Old 05-08-2007, 10:00 PM
sfbanchs
sfbanchs's Avatar
12 to 16 hours of labor depending on how generous the indie is i believ it is 2400 at the dealer
Old 05-09-2007, 11:57 AM
Q
Q's Avatar
clutch... or clutch and flywheel ?
depending on how many miles your car has done, you maybe advised to replace the dual mass flywheel.
.....or upgrade to a single mass....
Old 05-09-2007, 09:38 PM
jcb-memphis
jcb-memphis's Avatar
I just did the lwfw (964RS) with a clutch....I like it. See the thread in the 996tt forum. JB
Old 05-10-2007, 09:22 PM
cesar
cesar's Avatar
Right now the car only has 38k on it. Not sure when I will need a clutch or flywheel, just curious as to how much it's going to hurt the wallet at an indie or dealer. More then likely an independent shop.
Old 05-11-2007, 01:22 AM
Tim Wasmer
Tim Wasmer's Avatar
Parts are 700ish I think from Viper Bob.
It took us the weekend to do it.
Old 10-15-2007, 06:02 AM
TTCruz
TTCruz's Avatar
Hi Guys,
I just had some minor leacks repaired on my '98 TT that took major effort...according to the garage!! The engine was almost rebuilt to replace the RH head gaskets and rebuilt with new gaskets and seals. I was really dissapointed with the leaks, especially as I've only covered 44,000 miles on my baby......and it's not been on the track.
After the repair, my clutch now gives a slight judder when depressed. This judder starts just as the pedal is about to touch the floor.
Gear changes as A-OK and the performance is as expected - thrilling. I'm wondering if this is a sign of clutch wear and possible change or is this due to the engine being stripped and re-fitted with a mistake?
Appreciate your advice,
rgds
TTCruc
'98 993 Twin Turbo
Black/Black with Alluminium Highlights
Old 10-15-2007, 12:08 PM
bb993tt
bb993tt's Avatar
TT ... Who did the work?
Old 10-15-2007, 05:26 PM
sfbanchs
sfbanchs's Avatar
could be the accumulator
Old 10-15-2007, 05:37 PM
WHB Porsche
I'm Still Jenny
WHB Porsche's Avatar
It depends on your indie/dealer's labor rate. 12-16 hrs. x hourly rate. Here's a partial list of required parts from Pelican:
Pressure plate - $617
Clutch disc - $135
Throwout bearing - $110
Updated throwout guide - $69
Flywheel - $950
Flywheel bolts - $36
There are probably several other shims, etc. I've missed. The VB price of $2200 for everything sounds about right.
Quick Reply: Price of new clutch for 993 TT?
