AWD Dynojet? Safe for viscous coupler?
Planning on dynoing my car for a baseline next weekend and have heard stories (and read posts) of dynos being particulary harsh on the viscous coupler. What do you guys think about a 993tt on an AWD dynojet?
Need a baseline prior to Kevin's stage I ! (the turbo begineth)
Why do I feel so left out!
Dont do it!
It doesnt take that long to undo it - you will just end up frying the coupler......
Best,
Simon.
Best,
Simon.
Bob the Dyno-dynamics unit is not mechanically linked between the front and rear rollers..
Per Porsche requirements, you must have a dyno that has a physical chain-driveshaft or belt that will link the front and rear rollers..
Jason, I own a Dynapack.. It is not mechanically linked. Even though the electronic/sync control is very good front/rear. It isn't mechanically linked. If you want to dyno the 993TT pull/disconnect the drive coupler and then stick it on a Dynapack...
If you want back to back/very accurate results use a Dynapack. Run the baseline and then run the modded hardware.
Technical Guru
