please clear this up for me!!
i am sick of getting opinions from all kinds of people so i take this question to rennlist.
WHICH OCTANE BOOSTER IS BEST FOR OUR 993TT???
i have been told 104, lucas oil
I use lucas oil, and it works well. any answers are appreciated
Sebastian
Sebastian
I'm interested in the reponses as well... but let me expand the question: Does octane booster work? Does it actually raise the octane? How does it work?
None, waste of money... You can buy alot of 100 octane vs replacing a 993TT engine..
Your betting that a $10 can will save your engine... Why $10 if it worked??? Everyone would be buying the cheapest grade of fuel and slapping in a $10 in a can.. Pretty good return on the dollar or tank of fuel.. When you see that 100 cost $7.00 a gallon..
Put another way, Russian roulette with a can, vs a $25K engine rebuild..
Toluene can be used to blend lower octane fuel, or to raise the 100 octane fuel value... However the mixture ratio's are in the gallon quanties per tank vs cans.. My recent purchase was at $5.50 per gallon at Sherwin Williams..
Not Forgotten
I was under the impression that when an octain booster says it will raise your octain level by two points it doesn't mean from 98 to 100, it actually means from 98 to 98.2, therefore it's a waste of money in my book.
Talked to ***** at FVD the other day and asked him about mixing 50% 91 and 100 octane. His response was that that if you mix 91 octane with 100 octane, you end up with whatever the lower octane is and in this case it's 91. Now this is contrary to what I thought which is if you mix 91 and 100 you end up with 95.5 octane. Which is correct?
I've been asking local gas stations if they have two tanks or three. They have two tanks: 87 and 91. The 89 is simply a blend of the other two. So blending seems to be the accepted practice, despite what FVD said. I think it is safe to blend 91 and 100 and try get get 95 or 96 or so. Now Scott, on the other hand, needs 115 octane for his hot rod. That's a whole different ball game.
***** from fvd is just saying whatever he can to sell you something, i know i had my car there for a week and he came up with a laundry list of things i needed, none of which were necessary, i usually add lucas oil octane boost then fill up with 93 what will this raise my octane level to??
