Clutch/Gear selection/fluid problem...
Afternoon all,
Had my car on the track yesterday. On the last lap, I couldn't engage any gears unless I exactly matched the engine revs. I got back to the pits ok, but couldn't get it out of gear and the car crept creeping with the clutch fully depressed. Stopped the engine, took it out of gear fine, started it again and the pedal was very slack for the 1st half of travel and then started to engage. It was as if it was only half engaging.
I checked the Pentosin resevoir in the front and it was totally empty, with a small leak under the car in that area. I managed to get it to my mechanic by starting in 2nd/3rd gear and changing by matching the revs, which was fairly uneventful.
What do you reckon? (it was fine up until the last lap, so could it just be a burst pipe or maybe something more sinister?)
I don't quite understand the connection or difference between the front resevoir and the one in the engine bay, other than one is for the hydraulic clutch and the other power steering. Is that it?
It sounds like master line is broken or master cylinder is broken. If you have to change slave cylinder I recommend to change pressure accumulator same time.
It's connected to cylinder...
There was a leak just behind the front left wheel, ie right under the resevoir, whereabouts are the master cylinder and slave cylinder?
I'm hoping it's just the line between the two. Hopefully the mechanic will get a chance to look at it this week and let me know.
What are $$$ implications of slave/master cylinder failure? If it was the slave cylinder then would I not have power steering issues too?
Thanks.
Thanks.
The fluid behind the left front tire is overflow from the small Pentosin reservior due to a bad slave cylinder. 0% chance of line failure, however hoped for. Power steering will be unaffected, as the fluid level doesn't get that low in back. Part is about $800 US, labor will probably be substantial unless you DIY.
Was the small reservoir wet from outside?
There is no overflow pipe anywhere. If internal leakage occure in the slave cylinder, only natural way to overflow is the small reservoirs cap and the reservoir it self should be full to the brim.
It took me all day, a sharp tech might get it done in 4-5 hours. The failed slave allows the power steering pump to transfer the fluid to the front reservior where it overflows and drains out of the bottom of the trunk behind the left front tire. Normally the reservior would be full, but perhaps it occurred long enough ago that it emptied and dried out. My clutch still operated normally when I noticed the overflow and leakage. I'd guess the if the problem went on long enough for the clutch to quit working, that might explain the empty reservior.
Just spoke to him. He said all it needed was a refill of fluid and bleeding. No leaks apparently.
I find this hard to understand, but I do trust him so hopefully all is well.
I just have this niggling thought in the back of my head......
...but from what I can remember it was totally dry, on the outside. I thought I saw a leak behind the tyre but that could have been water/condesation from the A/C.
Time will tell.
Time will tell.
Time will tell.
Time will tell.
