PSS9 Help Needed
Ok guys
I figured out why my drivers side rear was 1/2 or more lower than my passenger side.
The guy I bought it from had the rear drop link replaced and the goobers that did the work put on the "stock" one which is 5 1/2 inches long vs. the correct one which is 4 1/2 inches long. They adjusted the shock down to clear the A arm. So they knew they were half assing it. Then they aligned it. No wonder it was a bit darty.
Question is, where can I get the right link and the other question is should the sway bar and link attach ABOVE or BELOW the A arm? It is above right now. But I saw a picture of a regular 993 where it was BELOW.
Anyone have any pictures of theirs?
Thanks in Advance.
Thanks in Advance.
Left a message for them this afternoon and did not hear back. From doing more research the sway bar should be below the A Arm to start with. Some of these hacks amaze me
Tim:
Do you know what sway bar you have on the rear ? - OEM ? OEM Adjustable (RS or GT2)? TRG ? The diameter or part no. may give us a clue.
Also, if you can shoot a photo through the wheel well of the end where the link mounts, we might be able to give a simple ID and best answer both your questions... Over vs. Under and what link to use. From there we can even assist as to where to set the sway bar mount on the shock body.
Stay cool. The fix is not so bad once you have the info.
Regards
Regards
Originally Posted by Tim Wasmer
...Question is, where can I get the right link and the other question is should the sway bar and link attach ABOVE or BELOW the A arm? It is above right now. But I saw a picture of a regular 993 where it was BELOW.
