Air intake temp sensor
Just received a replacement from VB and was hoping someone could post a photo of where I can find this piece to replace it.
Bob said I need to remove the shroud around the IC and then I will find the sensor near the throttle body.
Thanks!
Thanks!
Hal:
The sensor is easy to find. I wish I had a photo to post from work, but I think I can describe it well enough to make it obvious.
This sensor actually mounts into the intercooler in the center tank castiing. The sensor comes into the intercooler casting from the passenger side, just before the instercooler meets the throttle body. If you were to remove the intercooler, this is the one sensor you would need to disconnect. The sensor / connector is the type that uses wire bail type lock common to much of the Bosch stuff. Make sure you depress the wire retainer when removing the plug from the snesor.
The sensor uses one hex socket type bolt and seals with an o-ring. Be sure to wipe clean the bore the sensor goes into and lube the o-ring on the new sensor before installation.
Enjoy.
Enjoy.
The best lube is Master cylinder assy lube/oil. You can buy it at a NAPA store.. It will not break down viton or rubber seals. White lithium will work in a pinch.
