Chiptune my 993tt with powerkit -97?
I will "chiptune" my ECU, the problem seems to be when you got the 450 HK powerkit, not many companys have a chip for it. I will also mount decat or muffler bypass pipes. Anyone know where to go?
Thanks!
///Martin
Thanks!
///Martin
Originally Posted by Steve Weiner-Rennsport Systems
Martin:
The factory 450 HP Power Kit is comprised of a different ECU and a pair of K-24 turbochargers.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Precisely, what are you looking for?
I´m looking for 500+ everyday working HP. Which mods are needed?
I´m thinking: reprogramme the ECU, decat pipes or/and muffler bypass pipes, and maybe some kind of aftermarket airfilter?
Help me out :-)
Thanks from a fresh 993 tt owner...!
Martin,
Look for tuning kits for K24 Turbos. Those are the ones you have today. If you check the normal bunch of German Tuners, you will find that they have packages suited for your configuration.
If you just want to chip the car, you should be able to get 470-480hp. Even though some tuners claim up to 550hp, well it's still the same Turbos, same camshaft, about the same mapping so don't stare at the actual HP figure too much.
Check with Rickard 993 Turbo, he's done some homework on the K24 Turbos and what powerband you can get. I have the exact same setup as you do and I strongly suggest you get muffler bypasses. Turbo Center in Sthlm has mapping of K24 Turbos, Race Cats and Race Mufflers. It gave around 490hp on that car.
I hope you enjoy the car!
Cheers
Cheers
Fabspeed muffler bypass, Kevin's Stage 2 hybrid zero clearance turbo mod, Protomotive ECU upgrade, 5 bar adjustable fuel pressure regulator, Profec Bspec II boost controller. Results will be 540-560 HP at the flywheel. After sellin and installing mulitples of these kits on severall different dynos in different parts of the country this is where the HP winds up...
Bob that is very good kit and I wouldn't mind it myself at all. It is probably superior to the one I've got today.
The thing I thought of would have the benefit of not replacing the Turbos and it would be a bit cheaper. Since Martin already have the K24's, he could do a few tricks with them. Ok, he'd be not in the 540+ range, but still it would be quite descent. Dunno though if he'd stick with the K24's if the standard FPR would do, I suspect it would need to be replaced with tuned K24's also.
I know TB it flies in the face of all the RS tuners and slide rule projections, but that is real world with real world cars, multiple dynos, and customers that call me and tell me that my projections were right on when they went to their local dyno. I was hesitant to post this as it evokes strong feelings, but this is the way it works in real life over here. Maybe with the dollar to Euro we get a favorable HP exchange rate.
I'm starting my search for the right example and plan to do mods very similar to this once I find it. Obviously knowing a ball park will help me in the initial purchase being that obvious mod costs will follow.
Thanks!
Roland Mercier
Technical Guru
Originally Posted by higginsbeach
Where would I get the job done living in Maine??
