Viscous coupler toasted?
During a winter exercise session I noticed the front wheels were not spinning when the rears spun freely on the snowy road. Following the advise on a prior post, i jacked all four wheels off the floor, put the car in neutral and rotated a rear wheel. The fronts didn't move. Moving one front tire didn't move either rear or other front.
The prior owner had tires that were way out of spec and who knows what other abuse it may have been exposed to. I did have PPI done but this condition must have not been on their scope.
Does the engine have to come out to replace the coupler? Anyone had DIY experience? I found little help in the Porsche workshop manual (39-207).
Thanks for your response.
Dave
Dave
Geoffrey,
Thanks just thought I would ask.
I want to thank you once again for all of your help and unbiased wisdom over the last 2 years. Your input more than any other on this board has helped me achive the results I have. If there is anyway to repay the wisdom let me know.
I own a small business selling and servicing Canon photocopiers and faxes. If you ever have a need I will take care of you.
Tom
Tom
My method for testing the viscous coupler (very possibly invalid method) is to jack up ONE front tire and try to rotate it. If there is substantial resistance, then the viscous coupler is at least somewhat connected and working. Is this a valid test?
My front+rear half shaft (4) CV joints (8) were shot and seemed to mimic what you are describing. I replaced the wheel bearings while I was there also. Everything works fine now. Worth a look!
I can spin the rears too. Doesn't the coupler transfer a max of about 45% torque to the fronts? If so, you could still spin the rears while the fronts are pulling too.
Right?
Right?
Spinning the wheels in first, second, and third,
K24,
I know what your spinning means...
A) you are a madman
b) you need smaller turbos
c) you need a GT950 kit
d) you need a supercharged mustang or a Viper
Happy New Year!
A) you are a madman
Happy New Year!
CA993twin,
Following the test you suggested, lifting one front tire of the surface, it only takes 7.6 inch pounds of torque to turn the lifted wheel. That is not much more than overrcoming the drag from brake pads.
It seems that I have failed both tests.
BTW, this forum is awsome! I am truly grateful for the suppor of such a great group of informed folks.
Dave
Dave
I was hoping one of our "experts" would chime in and tell me if my method is valid or not. Dave, don't be discouraged just yet... it may not prove anything!
