Tuning options for the 993TT Motronics
Originally Posted by Kevin
Being able to program the early ECU, removes the added cost of buying a '97 ECU, at an average of $1,600.00
Is this a Kevin special or do you know if more tuners can do this
The far left hand Intel chip that houses the MAP's is extremely rare, and only a few people have these jewels.. The sad thing is they can only be programmed once, and in order to change your mapping you would need another chip. We are not talking about $100 chips but $1,000 plus and really it depends on who needs them and how much you want to pay for them.
The solution is not new, but getting the product made has taken some time and money. Since the stock Intel chip is soldered to the main board, the proceedure now is to install a chipset socket.
The intel chip is it a ROM/PROM/EPROM/EEPROM/Flash EPROM or perhaps something else?
Is the intel chip through-hole mounted or SMD mounted?
If you're setting a socket there, I presume the new chip will not be the same as the old one?
How will you replace the spot for the old chip with a socket?
If replacing the chip are you buying the chip on vendor or spot market?
Cheers
/M.
I am setting a socket to provide a new board that houses the new EPROM with a few other goodies like encryption..
