ABD, ABS, Brake Pad lights ON ??? Pedal firm!!
I was racing at Road America today and the ABD (Anti-lock Braking Differential), ABS, and Brake Pad lights came ON. The front pads were very worn but not the rears, so I changed the fronts. The lights stayed ON but the pedal felt fine. I then bleed the brakes and disconnected the battery so as to possibly reset the computer (ie lights). Turned the car ON after bleeding, lights still ON and the pedal is firm but takes both feet to engage the brakes!!! Any ideas????
