If you were looking for the world's best 993TT...
From what I have heard, it is the rod bolts. The crank is very strong. Unless you detonate or you have high mileage, I don't think your pistons and rings are at real risk. Head studs and fasteners are not the best either.
Originally Posted by hatchy
What would be the first to go on a high power 993TT? Rings? Ring land? Rods? Piston? rod bearings? crank? gaskets?
Originally Posted by Jean
TB, VB is using a TK I/C
and K24/26 like turbos, enough CFMs to flow up top, he could see some nice horses until heat soaks.
So it sounds like a lot of things break around the same power range (550hp?). Without getting into the whole turbo discussion, are stock K16s/K24s pretty much out of their efficiency range at above 1 bar? How much air do they flow at 1bar?
Stockboost, you seem new to the board, welcome. It would be great if you could give us more details and facts to support this statement? We don't see details in your signature.
As far as running more boost than 14.7 lbs of boost(1atmosphere) We ran 17 pounds of boost in a daily driven(40 miles a day) 993. Stricly boltons, stock motor, cams, and intake. We upgraded turbo's one more time to make 620 whp with race gas(~18psi) and some good old fashion tuning, but after driving that for about a month everyday, it started to lift the heads. So before that became a problem, we evolved to our current setup. And we now have the fastest street driven 993 in the country.
Originally Posted by stockboost
You won't see details in my signature about our car, or will I elaborate more than this about our past setups. Our car is a competitive street class car, so that is why I will not share everything that I know about this.
Any "public" pics or links you could share with us? Any videotaped acceleration numbers? Thanks
Stockboost, just saw your car pics on another thread, very nice.. But PLEASE, and I don't mean to flame anyone, if you want to make such claims, you should be ready to prove them and not say it is a secret. We are one big happy family here and we share information to benefit each other. Could be that your dyno is out of calibration because the numbers you mentioned above just don't go together: Stock cams <=> 750fwhp and 1.2Bar <=> 750 fwhp with stock heads and I/C.
, at least read the posts. ![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Please tell us us some more, if you've found an intercooler that works better than stock, we need to know....please
I swear I read them! As TB mentioned I just extrapolated your 620 Rear wheel hp to 750 Flywheel hp assuming it is a 4WD, because your previous post said RWHP. Sorry about the I/C when you said stock this and stock that, I assumed it was stock too, not that it would make a difference.
Seriously though, please share some more about the fastest 993 in the US, Devek said they have it, Prototech also, and some others on another turbo board, I am really puzzled
Well, there we go.. 17l-18bs of boost and he lifted his heads... Stockboost, there isn't much that you can do to a 993TT engine that hasn't been done before in the hardware department... You can sit on a camshaft grinder and sit at a bench porting and polishing your heads and turn around and say hush, hush... The quote " And we now have the fastest street driven 993 in the country." As Jean was kindly saying, puzzled? Old fashion tuning? So you have regeared your car with what ratio's? Please humor us all and snag a in car video of a 60-130 run so that we can time it... Please realize that some of us have spent more money in hardware than the purchase price of our cars... And some of us, play with these car for a living...
Please elaborate...
