Wastegate setting
Wastegate setting
While I’m waiting for a hand pump to set it according to the workshop manual, is this the correct way of measuring the distance on the wastegate rod? Workshop manual calls for a 3mm movement of the rod when applying 0.5bar pressure.
I remember reading somewhere that it should be between 29,5 and 32,5mm
