question on synchro
question: 993 turbo
coming to stop...unless car completely stopped and wait few seconds and then slowly put into first gear...tends to grind and chatter a bit.
does this sound like first gear synchro is gone/going?
anyone have cost estimate to R/R synchro
tia
tia
Was the clutch ever replaced? Any grinding with the other gears? Usually 2nd, 3rd synchro wears off before 1st gear. I would change the tranny oil first with Mobil Delvac synthetic 75W90 and do a test drive.
I would suspect the clutch since you drive on the hills, those Getrag G64 tranny are tuff. I live on flat land so very rarely I use 1st gear.
Yah, clutch might be hanging a bit and putting pressure on the gearset, but that has a particular feel in the shifter, almost a tightness. My opinion is different than above, I have been using the transmission factory recommended oil (which appears to be Shell Spirax) for myself and many others for some years now, and it seem to work better (smoother shifting and syncro engagement) than Delvac, especially for cold shifting. This is feedback from several people who have come through the shop and changed over. Viscosity is the same on paper, but the factory oil is noticeably thinner at room temperature (I know, I have pumped both).
Cheers,
Mike
Cheers,
Mike
Boost Junkie
Cheers,
Mike
Cheers,
Mike
