upgrading turbo's or keep stock
I had my shop send my original turbos to FVD in Germany as well as my ECU for upgrades...FVD upgraded the stock K16's to K16/24's. I also ordered their cams and sport muffler.
My shop changed the clutch to the Sach performance clutch. I kept the dual mass flywheel. I had FVD custom program my ECU for 93 octane gasoline and the turbos, cams and sport muffler.
fv
d
fv
d
400 wheel HP as measured on a Mustang AWD dyno corrected to temp and humidity and elevation. Depending on what you consider the driveline losses are in the 993tt drivetrain, it could be close to 500 engine HP
rlme36 (05-04-2022)
I upgraded my 993 T to factory K24 turbos. new diverter valves and a high pressure fuel regulator. The difference in power and torque is amazing. Yes, there is more turbo lag with the stock cats and new sport FVD mufflers, but not that much and with the FVD programmed ECU, the car is so much fun to drive. I've had this mod now for almost ten years with really no problems. It simply feels so much more power (seat of the pants) that makes the car even more fun to drive. I would recommend it. Pat
