Winter projects
Sure about 75 k. Conversion done back 2010
started misfiring and cel
found leaky turbos and pulled motor toooo kath Eads based on Kevin (Ultimatemotorwerks ) recommended
and cracks noted in ceramic liners
sice all is out will upgrade to pss10 suspension and deal with worn clutch
will be like new car probable in spring
any other thoughts on “while your there”
b
b
^thx
Not sure you can do much about the cracked ceramic apart from replacing the head. As long as there are no loose pieces, probably ok. A couple of mine had cracks but I decided to reuse them as they were otherwise good (previously reworked and two plugged).
Hmm here is my list of 'while you're there'
Plug wires
Upgraded turbo hoses (S car go)
serpentine belt (check pulley sits flush with fan - I have a thread where I had a problem due to casting marks)
Clutch, accumulator
Engine mounts
Cylinder temp sensors
New sound deadening foam
Check /replace
MAF
Alternator
throttle cable
Plug wires
Clutch, accumulator
Engine mounts
Check /replace
MAF
Alternator
throttle cable
Yes. My ceramic looks worse and in all cylinders
the wires are to be replaced to
the alternator pulley were always a little finicky
when it was converted the pulley and alternator were changed which worked well when running higher rpm but in street driving was never very effective so this will be corrected to
I hadn’t thought of engine mounts
the mechanic is pat Duggan and he has extensive experience with these turbo R. He has taken care or three of them that resides in this area
thanks bob
thanks bob
Replace power steering belt. Just something for all of our engine out R&R. Car is getting all the love this winter. Am sure will drive like new when buttoned up..
