musing after tacking 993 turbo for 13 years
#31
Great to see you are enjoying your car so much after 13 years!
I started working on the integration of the GT2RS IC's many years ago and then got sidetracked and stopped. I first built a foam core mock up and thought it would be very close to fitting under the stock tail. I didn't want to modify my tail, not even the slightest amount. The clearance issue is primarily on the left side of the cooler.
I bought a used set of IC's. and machined a manifold/plenum out of a block of aluminum.
Made a baseplate and modified an aluminum elbow.
Here is where I left off.
I hope to jump back on this at some point and finish it up. If I were tracking my car I would definitely figure out a way to get this done.
