993 Forum 1995-1998
Is the CR-1 Casette player harness the same for a CDR-210?
Old 06-29-2017, 12:52 PM
hexagone
hexagone's Avatar
Default Is the CR-1 Casette player harness the same for a CDR-210?
As noted above.
Have the harness from a 1995 993, will a CDR210 from a newer 993 be compatible?
Old 06-29-2017, 04:20 PM
2RedPorsche
2RedPorsche's Avatar
From the looks of your picture I'd say not. I have a CDR210 in my 95 993 cab and it looked different on the back. My car didn't have its CR1 harness anymore because the PO had cut it off to install an aftermarket Piece of S@&t that I quickly removed! I had to splice my cars wires to the harness that came with the 210 I bought from a fellow Rennlister.
It turned out great and looks appropriate in the dash.
Old 06-29-2017, 05:53 PM
Spyder_Man
Spyder_Man's Avatar
No they are not the same. You'll need an adapter from the CR1 harness to whatever you want to connect it to.
The fine folks at bergvillfx.com would probably be able to help you out as they sell numerous harness adapters for Porsches.
Old 06-29-2017, 07:30 PM
jansan946
jansan946's Avatar
Your answer may be somewhere in this thread: https://rennlist.com/forums/993-foru...s-pinouts.html
I agree: Patch cords to adapt the CRD-210 radio to your car's existing plug/harness logic is much more preferable than cutting and splicing.
Hope this helps!
Quick Reply: Is the CR-1 Casette player harness the same for a CDR-210?
