I have a theory about Distributor Failures
Recently I sent my distributor in for a new belt and other servicing as needed. When I removed it with the belt intact at 100K miles the gear turned effortlessly signaling that the bearings were probably in good shape.
Each time I replace the rotors and caps I put a small amount of motor oil on the components under the shield below the rotor. Upon removing the rotor I noticed that there was a small puddle of oil along the lower of the two rotor housings. This is probably excess oil from earlier lubrications.
This is my theory; If the mechanism is oiled with each rotor/cap change does it contribute to keeping the bearings lubricated and so they do not dry out, overheat and become damaged?
Conversely, if the distributor is not lubricated when the cap and rotor are replaced do the bearings eventually run dry and wear out?
Other's thoughts and experiences?
You may be thinking about the 964. The fix was added in 1993.
I did notice once that my hose had fallen out, down at the bottom of distributor where its hard to see. So that's a good thing for everyone to check. Once it falls out, it aint doing much good any more.
I understand the ozone issue with the belt but seeing that my belt is 20 years and 100k miles old I think they have that issue licked. My car does have the vent tube.
The bearing issue is one where a bearing begins to fail and the added torque demands on the belt, as a result, snap it.
Could it be after 20 years the seals on the bearings are not so well sealed and the incremental additional lubrication from above provides some gravity feed to them? Looking at the application and the very low forces involved a little lubrication would go a long way!
Other's thoughts?
Andy
Other's thoughts?
Andy
I haven't been into mine yet, but I like the idea and can't see how it would hurt. I'm going to oil mine, that's for sure.
Did you just use normal motor oil? If so I'll go add some brad penn this weekend
The vent tube greatly extended the life of the belt over the earlier non-vented distributer. However, I still believe ozone to be the leading cause of distributer failure over bearing lubrication.
It's not uncommon to see a 964 or 993 these days with the vent tube missing or not installed properly.
Another concern is the ozone resistance of the replacement belts being used.
Only time will tell.
Edit to ad: Not saying it's not bearings, makes sense to keep an eye on them.
Think about you are a brand new set of bearings built in circa 94-98 from Porsche's bearing distributor with fresh grease inside.
Now you have spent 20+ years in a hot distributor with ozone with imperfect seals, maybe moisture too.
Would you dry up?
We used to lube up the weights & shaft in all distributors during tune-ups years ago, really made a difference.
I think putting some type of oil that will get past the factory bearing seals would help... ACf-50 is what I like...
Thanks,
Dave
Would you dry up?
Thanks,
Dave
