Electrical issue (mirror and cabin fan)
I was in the car with the fan working at speed 3 and decided to adjust my electric mirrors. As soon as I press the mirror switch, the fan stops... and starts a few seconds later.
How can this happen?
I cannot see why these could be related, unless there's a short circuit or similar in your car.
The main blowers will be stopped by the Climate Control Unit if there are issues in the rear fan when you need hot air. Try setting the temperature **** to minimum, does this happen then?
Cheers,
Tore
Cheers,
Tore
Cheers,
Tore
Cheers,
Tore
BTW I had my rear blower removed but I did use the recommended relay.
