Should I replace distributor belt or not?
If its recommended to replace the belt, does anyone have any recommendations who could do this job with fairly fast turnaround? This job I prefer to outsource. I live in Louisville KY.
Anyway, here are few pictures.
I took one picture you can see one of the rotors, so if I need to point them that way, I might be good. Thoughts?
Next items on the list
- Fuel filter
- Power steering flush
- Brake Flush
- Hydraulic clutch flush
- Spark plugs
- Lower Valve cover gaskets, not sure if top are leaking, lower for sure.
- Timing chain cover is leaking ( not looking forward to that one, might just try tighten bolts and wait on that one)
- SAI check valve and injector cleaning
- Fister Stage 2 install when all set and done
If you have not marked the position on the distributor though then you will need to find TDC for piston one. What I would do if put the crank into one of the TDC positions (the crank pulley is marked so match the mark to the mark at the bottom of the fan housing), pull the lower spark plug on piston one, and use a leak down gauge to see if the piston holds pressure - it will only do that if its truly TDC on piston #1. If not, rotate the crankshaft 360 degrees until the mark is match again, and it should be truly TDC on the compression stroke for piston #1. Now you can put the distributor back in, ensuring the position of the rotor once the distributor is seated is pointed to #1. If you cannot do it this way, you can do it other ways, such as checking the rocker positions if the cam cover on bank 1 is off, or line up using the TDC mark and see if the car runs ...
BTW, pcarworkshop.com appears to be up, what did you see?
Cheers,
Mike
What I would do is the installation above then check if the position is correct before starting the car.
If you look at the distributor cap, you can locate the post for piston #1. Do that by tracing the spark plug wire from plug #1 - left hand side of the car, the closest spark plug to the rear of the car. When the distributor rotor is pointing to that post (which you can approximate by eyeballing the post alignment with the body of the distributor) that means that #1 piston should be at "top dead center" or TDC. This is when the #1 piston is at the top of its travel in the compression cycle, and if the spark plug sparks, the compressed fuel mixture will ignite and push the piston down. Rotate the crankshaft clockwise (usually done with all the belts on and rotating the alternator shaft clockwise via the big retaining nut, which through the belts rotates the engine) until the rotor points to this post.
If you have rotated the engine so the distributor rotor points to the #1 post on the distributor post, you should also see a mark on the crankshaft pulley align with a mark on the bottom of the fan shroud. If they are aligned (or very close, you can perfectly align then with some slight rotation), you will be at TDC.
So, if your rotor is pointing to what is the post for #1 piston (determined by that fact that the spark plug wire for #1 piston is plugged into that post), and the main marks on the crankshaft pulley are aligned with the mark on the shroud, you should be good to go.
I would post some picts but I am away right now so do not have access to my photos.
BTW, you can, if confident skip my checking cycle and just try to start the engine. It will be pretty obvious if the timing is off when you start it.
Cheers,
Mike
As others noted, putting back in an indexing is pretty straight forward.
It's been a while since I had my distributor rebuilt; but, at that time bearings were non-existent or extremely scarce in the world. Guys like Steve Weiner "may" have a small stash of bearings, but I'm not certain. Unfortunately, Porsche did not use a standard sized bearing. And, you may not need them. They rarely go bad.
+1 on changing out the belt. These belts don't wear out. The belt material deteriorates from the effects of ozone. So, a belt can look fine, but may be becoming brittle. And, they will simply then break. If you elect to replace the belt yourself, be aware that the two distributor heads need to be aligned exactly as they were when taken apart. There are instructions on how to do this in the literature.
Thinking about doing the same. Roughly what does Steve charge for this and what was the turnaround time?
TIA
http://www.williamknightperformance....tributors.html
