Should I replace distributor belt or not?
Happy I just found this thread.
So it is not important to set the engine to TDC. check
how much force is required to get the distributor out? I am using a small slide hammer with a flat lip which fits really nice under the low edge of the distributor . I am afraid to hit it too much. A lot of firm force is still not pulling it out. I can make it wiggle a bit side to side, but not up.
Technical Guru
But it is so much easier if you do and it only takes a few seconds... Just rotate the engine by hand until both rotors are pointed at the two alignment marks on the distributor. Then you don't have to worry about anything when days, weeks or even months later it comes time to put everything back together. If you are off by a rotation, the engine will backfire and blow the intake manifold loose.
Now with the new belt in place, when rotating clockwise by using the primary rotor, I can’t perfectly align them- see white mark where it should be. When the secondary rotor is in the perfect spot, the primary can only be a little forward or a little back - this is when moving the belt either one notch either direction and aligning the shaft - see blue marks.
Any suggestions?
Technical Guru
any thoughts about the marking alignment ? The Bentley manual states that “the distributor marks line up approximately, not precisely”.
I wonder how how much tolerance is acceptable and if more important to line up the primary distributor or it makes no difference.
