Anybody use an oil extractor?
I'm thinking about buying this:
https://www.griotsgarage.com/product...d+extractor.do
Anybody here use this or one of the other similar fluid extractor's available to empty the oil tank before removing the plug and filter?
Thanks in advance .. any help appreciated.
JP
JP
JP,
Harbor Frieght sells a similar pump, not in physical configuration, but in net results. Its about 8 bux. I use it for pumping differential oil, into the case of my Tacoma. I use the gravity method (remove the drain plug) to empty the oil tank on the 993.
M. Schneider (05-14-2023)
Thanks ... I did find a couple threads since posting. My intention is to avoid the 'spill and mess' that everyone says is almost inevitable because of the location and angle of the tank plug and filter. Looks like I can empty the tank by siphon and at least mitigate most of that .. then pull the plug and filter on the sump and the filter on the tank and be good to go.
oh ... and for those others that are thinking about it ... you can go down through the oil fill neck if you remove the filler extension tube. It's got a screen filter on the end of it .. just pull it up gently and when it resists keep pulling, it's just a friction fit. Of course there will always be at least a 1/2 quart to a quart of oil left in the lines etc. just the nature of the beast.
My Indy takes half the box from the oil filter and wedges it into place to deflect the oil away from the undercarriage and directly into the receptacle tank. Works very well at eliminating the mess.
Use the extractor for my VW. Unfortunately, my extractor holds five quarts and the VW holds 5.7 quarts so I do it in two loads. The VW dealer informs me that they use this method. For a 993 not sure of the advantage as one needs to replace the oil filter on the oil drain housing anyway and the drain plug is very easy to get to. On the VW the drain plug can only be reached by unbolting structural components so using an extractor is a no-brainer.
On my993 the amount of oil that drains from the engine case is so small that for other than inspection reasons just draining the oil in the oil tank may be a reasonable alternative.
Great idea. I was going to get one of these form-a-funnel things for my next oil change, but I think I'll try the foil idea instead.
I use this one for lawn mower and my Toyotas. Works great.
Thanks for all the input guys. I appreciate those trying to save me from myself but I fear I'm a lost soul. I pulled the trigger ... 15% off free ship (after adding some dry car wash spray ... heh ... ) made it worth the gamble.
What I like about the Griot's unit is you pressurize the tank with a few pumps to start the siphon then walk away. It fills itself and shuts off automatically when it's full, will work up to 90 weight viscosity and after talking to Griot's and another private user, it's fairly fast with warm oil. Also comes with a brake system bleeding tool which is a handy feature.
I know ... I'm hopeless. This is what happens when you fix up your garage. A lesson to take note of.
Pull the plug, it will test you ability to problem solve, keeps the mind active and sharp, which pays dividends when driving the 993.
Foil funnel/ramp/half pipe will be your friend. More mess dropping the little (engine) filter.
M. Schneider (05-29-2020)
I have the original, made by MityVac, I think. Great for the E46 BMW, easy access thru dipstick hole. And the oil filter access is so easy also. I get the oil real hot before changing. gotten it down to about 15 minutes.
For the 993 I use a rubbermaid underbed storage container when doing an oil change. It is low and covers all of the possible drip areas when removing the oil filter. Afterwards I prop it up a little and use the extractor to suck out the oil, wipe the container and put it up.
Works great for catching debris during a brake job, just put it under the area, wash everything, then hose out the container when done.
Used it a time or two for odd jobs. Once when I overfilled a little on the oil change, just sucked a little out. Next when doing a power steering fluid change. If you think out of the box, it is pretty useful.
