993 Forum 1995-1998
Need help in reinstalling original rear spoiler 993
Old 11-30-2016, 06:09 AM
YellowDieselGolf
YellowDieselGolf's Avatar
I've just checked my RHD 993 and the spoiler is powered from the right side of the engine bay.
Maybe you could take the cover off your airbox (for extra room) and double check for the wiring.
Old 11-30-2016, 08:44 AM
P-daddy
P-daddy's Avatar
Agreed. Remove your air filter cover to have better access. Look way deep in the fuel filter area, behind the dipstick handle, and possibly sandwiched above the foam engine pad.
Old 11-30-2016, 09:23 AM
SpeedyC2
SpeedyC2's Avatar
Originally Posted by P-daddy
...and possibly sandwiched above the foam engine pad.
This is what I was thinking. The pad looks to be in very good shape, so maybe it was replaced? If so, maybe the plug is above the pad - or maybe it was removed...
Old 11-30-2016, 03:08 PM
356Downunder
356Downunder's Avatar
I've got a RHD C2S and have just been thru this same exercise.......it will definitely be there and more than likely tucked under the pad on the RHS.........with the airbox removed you'll be able to find it without much trouble at all.
Old 11-30-2016, 09:47 PM
hazzelth007
hazzelth007's Avatar
Guys, you all are life savers! The solution is opening the airbox and the harness sits beautifully behind the airbox! Connected it and the rear spoiler works now.
Thanks all!
Old 12-01-2016, 11:39 AM
Onami
Onami's Avatar
Nice work everyone!
Old 12-04-2016, 11:06 AM
pp000830
pp000830's Avatar
Received 1,502 Likes on 1,062 Posts
Withdrawn
Old 12-04-2016, 12:09 PM
Foxman
Foxman's Avatar
Originally Posted by ilko
Yep, my '96 Carrera came with the Aerokit package from the factory, part of the Exclusive program. The wiring is present, the button in the center console and controller under the dash are not. I installed them along with the motorized tail and everything worked fine.
Lucky for me, it appears my factory aero kit II car also came with the controller under the dash.
Quick Reply: Need help in reinstalling original rear spoiler 993
