Stupid question on siphoning gas
OK....so I want to get some older gas out (she's been sitting a bit) and I tried to get the tube from my Checker Auto pump siphon down in there....I remember this always was kinda difficult.
Question is, has anybody found a good technique (or product) for easily getting gas out?.....I'm probably just going to find some smaller plastic tubing & keep trying to snake it down in there.
Any suggestions appreciated.....GreggT
Greg;
I wouldn't risk it. Jack the car up and remove the fuel pump access panel and remove the inlet line from your tank. It will take you a little longer, but you'll drain most of the gas. I'd disconnect the battery of remove the fuel pump relay.
