993 Forum 1995-1998
Mobil 1 for RS
Old 07-14-2003, 08:35 AM
Roygarth
Roygarth's Avatar
Post Mobil 1 for RS
Must buy Mobil 1 for top up. Is there only 1 type/spec of Mobil 1?
UK boys - do Halfords sell it?
Thanks in advance!
Piers
1996 993RS
Old 07-14-2003, 08:44 AM
ksimpson
ksimpson's Avatar
Post
The only one I've seen in the UK and Ireland is Mobil 1 0 W40. Make sure you don't get the diesel version, the cartons look similar. Yes, Halfords sell it.
Old 07-14-2003, 05:01 PM
DJF1
DJF1's Avatar
Default Re: Mobil 1 for RS
Thanks in advance!
Piers
1996 993RS
in the US 2 types are very popular for our cars:
1. 0-40W with the green bottle cap
2. 15-50W with the red bottle cap.
Old 07-15-2003, 01:24 AM
johnfm
johnfm's Avatar
Piers
you need the Motorsport (15W-50) as far as I know. Yes, Hlafords do sell it (surprisingly), it is £34.99 for 4 litres. I have yet to find another supplier on the 'high street'.
Old 07-15-2003, 04:12 AM
JohnM
JohnM's Avatar
Just to confuse things I was in a Porsche independent workshop a few weeks ago and they were using Mobil 1 "S" for their oil changes, seems to be 0W40 but with a further additive to make it even more slippy.
Old 07-15-2003, 04:48 AM
johnfm
johnfm's Avatar
The 0w-40 is certanly used for all the water cooled 996/boxster cars ( saw a pallet load of it at JCT last week).
If in doubt, call Jonas at JZM!
Old 07-15-2003, 05:34 AM
Roygarth
Roygarth's Avatar
Thanks Guys...........I'm completely confused now....as indeed I knew I would be if I asked an 'oil' question!
Brgds
Piers
1996 993RS 30K miles
Old 07-15-2003, 10:53 AM
Bins
Bins's Avatar
I'm glad I'm not the only one confused.
I need to get some to.
By the way JZM generally use Castrol SLX.
Old 07-16-2003, 02:44 AM
Roygarth
Roygarth's Avatar
FYI I've bought 5 Litres of Mobil 1 0-40W for an entirely reasonable £35 ($58)!
Brgds
Piers
Old 07-16-2003, 04:09 AM
Flying Finn
King of Cool
Flying Finn's Avatar
Piers,
Use 15 w50.
I believe the only reason Porsche recommends (now, used to recommend 15 w50) 0 w40 993s is that in colder climates, hydraulic lifters might have problems.
Since you don't have them, you can't have the problem either.
Probably 0 w40 would be good to use during winter there, but for hotter months (you do have those too? ) I'd definitely use 15 w50. That's what my car gets every time.
Last weekend when I changed my oils (after three track days & about 3000 miles), I noticed that there was practically no metal shavings in drain plug, just so little that you could see something but it was so clean that I could've put it back w/out cleaning.
FYI, Some here have reported awful looking oil (inspected after oil change0 when they used 0 w40. I'm sure you can find that post if you search.
Old 07-16-2003, 04:45 AM
Christer
Christer's Avatar
Strange, on my 964 they use Castrol Magnatec (10-40W).
Piers, if you want the best you should get the Castrol Formula RS IMHO. It is 10-60W. I can I think give you the phone number to a place that sells it for around £32 per 4 litre 'can'...whether it's worth doing this or you need it can only be your decision.
Old 07-16-2003, 05:25 AM
Bins
Bins's Avatar
Sorry, I meant on the 993's they use SLX.
Pre 993 its Magnatech.
Im not sure what they use for 996's.
Old 07-16-2003, 05:43 AM
Surj-993C2S
Surj-993C2S's Avatar
My OPC used Esso Ultron (a semi synth). When I questioned them about it they said that in their experience. using thinner fully synth like Mobil 1 tends to lead to increased leakages because they reckon the engine flexes more from temperature changes due to its air cooled nature. I top up using
the gallons of Mobil 1 I have stocked up (its circa £22 for 4 litres from Costco) which they said was fine.
Old 07-16-2003, 05:57 AM
johnfm
johnfm's Avatar
Surj
the gallons of Mobil 1 from Costco is the 0-40W stuff. It is NOT the 15-50W Mobil 1 MOTORSPORT.
Old 07-16-2003, 11:46 AM
noony
noony's Avatar
Piers, I've seen your RS-beautiful :-)
Quick Reply: Mobil 1 for RS
