Clutch problems 993
Clutch problems 993
My clutch is chattering in reverse and at times taking off from a stop. this has been intermittant. It also when is doing the above will chatter on down shifts between gears. Now the thing is slipping on acceleration with powershift between 1st and 2nd ( 3 times now ) afraid to try more trial and error antics. It launches ok in first but when you depress the pedal make the quick shift and release the pedal; the engine revs higher than the car is moving...until it all catches up with itself. Got any ideas...adjustment etc replace. I watch the site almost daily be glad to answer more question to get to the bottom. Thanks Paul
