Front drop Link question for m030 ARB's
Subscribe
Jul 6, 2016 | 01:22 PM
I'll be switching out suspension soon to include m030 sway bars. Do i need new front drop links and if so what is recommended. For the rear, understand i can use what comes with the shocks? I'll be ordering Bilstein B8's along with m030 ROW springs. Car will be set to ROW height. Thanks
Reply 0
Jul 6, 2016 | 02:30 PM
I went with PSS10's and M030 ARBs and I did need front drop links. As I recall, I was able to use the rear drop links that came with the PSS10's. But if you need the rears, the PN is 99333307303, $169.40 ea at ECS Tuning.
The fronts are:
Left - 99334306900
Right - 99334307000
I purchased them from ECS Tuning 8/14. The Left was $146.49 and the Right was $138.71. I have no idea why they were priced differently!
Reply 0
Jul 6, 2016 | 03:20 PM
Keep what you have.
Reply 0
Jul 6, 2016 | 07:54 PM
Thanks VA993. While replacing the suspension, any reason to replace the front tie rods? Believe they are the original and car has 40K+ miles. Front contorl arm front/rear bushings will be replaced with ER bushings.
Reply 0
Jul 6, 2016 | 09:29 PM
Get the RSR tie rods from tarret. I would replace your current ones. The ball joint on inner tie rods has plastic inside, which wears out and causes play.
Reply 0
Jul 7, 2016 | 10:51 AM
Quote: Thanks VA993. While replacing the suspension, any reason to replace the front tie rods? Believe they are the original and car has 40K+ miles. Front contorl arm front/rear bushings will be replaced with ER bushings.
I replaced the tie rods and ball joints with OEM when I did the suspension. It just makes sense to do while you're in there, forget mileage,they're close to 20 years old by this point. I did Walrod bushings. You're approaching your suspension upgrade very similar to how I did-I know you'll be as pleased as I was with the result. Just be sure to get a proper alignment done by a shop that knows 993s and how to do it right. That is really the icing on the cake for this project.
Reply 0
Jul 11, 2016 | 11:44 PM
Bilstein shocks arrived from Carrenewal. Talk about fast service. These guys rock.
Reply 0
Jul 12, 2016 | 12:05 AM
^^^+1
Reply 0
Subscribe
