New! FDM AWD transmission mount
Basic Site Sponsor
Basic Site Sponsor
We have a new awd transmission mount for the 964/993.
http://fdmotorsports.net/fdm-awd-trans-mount/
FDM C4/AWD Turbo Transmission Mount for the 964 and 993
$159.99
Item #: TM1002A
¨ Improved shifter feel, this item will compliment the Golden Rod shift rod
¨ Improved Clutch engagement, less weight transfer
¨ Increased feedback and a more visceral driving experience
¨ Less engine movement, especially during off/on/off throttle transitions
¨ Made from 6061-T6 aluminum¨ Made from 6061-T6 aluminum
¨ Type II anodized to MIL-A-8625 (military spec)
¨ Urethane bushings
¨ Black oxide coated, grade 12.9 hardware
$159.99
Item #: TM1002A
¨ Urethane bushings
Originally Posted by NYC993
Order placed to go with my 2wd conversion.
Yes, since attachment of the tranny is the same. They have another mount more suitable for turbo, not sure if you already have it, in which case you might not need the new mount. In either case let me know and I can ask Darin to addextra. He is waiting for a few porshe parts for my conversion kit, so my order won't leave till later next week.
2wd conversion retains the original gearbox and the same attachment point as regular c4.
True 2wd car has a slightly different gearbox with different attachment. Others can correct me if I misstated something.
Basic Site Sponsor
Basic Site Sponsor
If you are converting an AWD car to 2wd, it will work, if you are using the AWD transmission. I hope that makes sense
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
Do you have this?
http://fdmotorsports.net/993-turbo-c...n-trans-mount/
Thanks Darin for the clarification. Guess it will fit my turbo and should order it.
