Small run of Bumperette Delete Inserts available.
#137
I purchased the bumperette deletes (thanks (GMorat) and plan on combining with Euro side lenses and HID Euro lights tp repace stock fogs. I noticed the bottom screw thread on the bumperette could be an issue as I want the option to return to stock. Can the Euro side lenses be installed without modifying?
#138
When I first did this, the two bolts/studs on mine pushed the euro lenses out by a couple of mm. I mulled it over (permanent mod....) then took a few mm off each stud. Euro lenses are now flush, and the fugly rubber bumpers can still bolt back in if desired.
waizone (06-28-2020)
#139
I sold my first 2 993's with the bumperette deletes in place and the parts in a box that just came with the car so it's probably safe to say you won't be going back. One other thought would be to heat the back of the euro lens and then make indents without making holes by heating the plastic but this may be trickier than it seems. I would mark the correct position by putting some paint on the mounting bolts and then just placing the euro lenses so you get where to modify as accurately as possible.
I have a document that I can share with anybody who wants it taht details installation as best as possible and it touches on all these points. PM if interested.
Hope that helps!
#140
Hello,
Hope all is well, i wanted to ask if you have still left in stock and if so i live in socal would love to get them as i planning to convert my bumper. Any help would be appreciated
Cheers
Cheers
#142
PM sent
911F1 (03-29-2021)
#145
