In need of the forum's help assessing a new idea...
#46
Thank you so much! There may be a bit of give and take in expanding the height range, but it can be done. I'll keep the forum posted
#47
I greatly appreciate that! I believe we can increase the maximum height in the production model, and we'll be working on that. Thank you!
#48
Great idea! I just wonder if the adapter part is to tall for lowered vehicles. I know with my current jack and height of vehicle it wouldn't clear. A low profile jack like you have in the video would be necessary. Just something to think about. Not all people will have the low profile jack.
#49
However, in cases where that may not be an option due to the cost of purchasing a new jack, there is an easy workaround, ie lifting the car with the jack by itself, then laying a piece of 2x4 flatly under the tire nearest the jack to give you that extra clearance, lowering, then lifting again this time with the center piece in place on the jack.
Ideally I would like the stands to accommodate as wide a range of users as possible without having to use the above method, and I have another patent pending on an alternate center piece that is specific to the situation you described, so if there's enough demand for it I may offer it as either an alternative or an add-on, but so far I've found that in most cases it hasn't been necessary.
Thank you for expressing that concern, and best regards!
#50
Brilliant idea.
My only thought would be perhaps adding some sort of c-clip to the end of the pins. Likely unnecessary as they wouldn't move under load, but could shift or slide out with constant lower/raising height changes?
#51
I greatly appreciate the compliment and suggestion about the pins! I'll take a look at that c-clip option. Thank you!
#54
Yes, those have actually been the preferred pins. Very convenient and held firm. There was some concern initially that the ball would waller out the holes over time, but after hundreds of actual testing that wasn't the case in the slightest. I'm always open to suggestions though. Thanks and best regards!
#55
Received 5,409 Likes
Will the, or can the, feet to be covered with rubber or a nylon glide so we don't scratch our epoxy floors?
#56
The shear strength of the pins was absolutely included in the calculations. Here's a quick rundown on the pins we've been using: 1/4" steel and each is in double sheer and capable of sustaining up to 19Kn (1.9 metric tons of force per pin). Each pin will only need to bear half the weight of whatever each stand is supporting, so you would have to load 4 metric tons on EACH stand before you approach pin failure. Considering that the stands are rated to 2 tons/pair, that gives you a safety factor of 4 for each pin.
Again, thanks so much for bringing that up!
#57
I have several designs on stands with various types of footings and coatings, but as is the bottoms of the bases are actually slightly rounded off as you can see at the 40 second mark in the video. I've dropped the jack a bit too hard on occasion with the stand attached, and there was not any marring to smooth cement floors, but I will look further into doing something for epoxy floors as well. Thanks!
#58
What are their weight capacity?
#59
Great and largely innovative concept! I recently purchased a set of jack point jack stands. They're awesome. I can adjust the height of the Jackpoint jack stands a bit with blocks underneath, but your height adjustable legs appear to afford a better solution.
The jack point jack stands however, while pricey, appear to be more solid than the hollow construction in your design. It's not uncommon for a floor jack to drop quicker than expected, and even a two ton jack can fail if a one ton load is dropped too quickly. And unlike the Jackpoint stand there's a potential for just one of the four legs to take the brunt of the load and fail. Just wondering if all of this has been thought through and fully tested...
#60
Like it, like it a lot and would buy a set if they were for sale. I see a few comments on the pin, definitely over design it even though you might not need it. It gives a sense of security for fraction of the cost. Might consider a larger gap between the bottom of the car and the horizontal bar for a wrench to get at hidden screws or bolts. Nice to have them light and durable, aluminum or carbon fiber is good. Lastly looks and finish. I think most people would pay more for those, you are talking to the Porsche crowd.
